05 sti no mods , Idle issues ?
Results 1 to 7 of 7
This is a discussion on 05 sti no mods , Idle issues ? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; When I start the car the rpms jump between 300 and 1000 sitting at idle . It's not a clean ...
    Jun 2012
    When I start the car the rpms jump between 300 and 1000 sitting at idle . It's not a clean rpm fluctuation the car shakes quite a bit. If it sits in idle long enough the car will die. While driving in the lower gears the car will stall as well . Any input on what the problem might be would be appreciated thanks
    You cannot measure 300 rpm, can you?
    Have you cleaned the IACV?
    No CEL?
    - Al Stewart
    Jun 2012
    No I can not measure 300 rpm that was a rough guess buy how low it dropped on the gauge. Yes CEL I'm going to get the error code tomorrow and clean the IACV thanks for the suggestion.
    Ok if no luck post code number and hopefully you'll get an answer here.
    - Al Stewart
    Moderator Donkey's Avatar
    Da boonies,Va
    http://www.clubwrx.net/forums/genera...-question.html
    The STI is "drive by wire" and has no IACV. Try cleaning the MAF sensor. It could also be time for a plug change. The DTC will pretty much narrow the issue down hopefully.
    2002 FORESTER S
    1998 FORESTER S
    Jun 2012
    Yup no IACV , reset the CEL and cleaned the maf sensor runs like new . Thanks
    Oops sorry am hard of reading, good to hear its fixed.
    - Al Stewart
