Results 1 to 4 of 4
This is a discussion on Need help ASAP car wont start... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello, I need to be pointed in the right direction. I finished replacing my water pump on my 02 wrx, ...
    Jun 2012
    Albuquerque,NM
    Hello,
    I need to be pointed in the right direction. I finished replacing my water pump on my 02 wrx, reinstalled the timing belt and all the idles, made sure that every thing was lined up and matched. I turned my car on and perfect it didnt skip a beat. let it sit over night and now the car turns over and sometimes idles at around 300rpm and then dies. All the timing marks are dead on. and i dont have a CEL. can someone point me in the right direction?
    Thank you
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Did you bump or disconnect the cam position or crank position sensors?
    Jun 2012
    Albuquerque,NM
    I haven touched them. I am in the process of checking my fuel pressure.
    Jun 2012
    Albuquerque,NM
    the fuel pump is working perfectly..the cam and crank sensor are connected and now it feels like it wants to start but just gives out in the middle of a crank????
