Slight ticking noise after oil change. Should I be worried?
Results 1 to 15 of 16
This is a discussion on Slight ticking noise after oil change. Should I be worried? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just picked up this WRX a month ago it's a 2005 with 128xxx on it. It's a one (female) ...
    May 2012
    Bat country, Nevada
    I just picked up this WRX a month ago it's a 2005 with 128xxx on it. It's a one (female) owner car that was Maintained well. It still runs great and pulls hard but after the oil change I got Thursday it seems like the motor is making a ticking noise that is present warm, cold, at idle and through the RPM band. Beings that I just bout the car I'm super paranoid about it... Does it sound ok to y'all? Oil was castrol GTX high mileage 5w-30.
    2005 WRX idle. Sound ok? - YouTube
    Sent from my iPhone
    KHP
    KHP is offline
    Registered User KHP's Avatar
    Oct 2010
    Reno, NV
    Sounds normal to me...
    2011 WRX Limited Spark Silver (5 Door)
    Registered User Ryouko's Avatar
    Mar 2012
    South Jersey
    If you are trying to troubleshoot it, one thing I would try is blipping the throttle a little bit. At about the 12s mark in that video, you are aiming the camera at the two cables that connect to the throttle body. They are just in front of the passenger side edge of your intercooler. It may make the sound louder and easier to find the source of.
    Registered User Jables_WRX_Junki's Avatar
    Jun 2012
    PDX,Oregon
    do you kno if the previous owner used synthetic or not?
    May 2012
    Bat country, Nevada
    Not sure, they used a pennsoil 5w-30 is all I know.
    Viscosity correct; noise IMO unlikely caused by oil itself.
    Jun 2012
    PDX,Oregon
    if the previous owner ran synthetic. you will have to as well.
    I don't see why, sorry? Also, what is a synthetic under that reasoning? Are hydro cracked bases also synths? I don't follow the logic.
    Jun 2012
    PDX,Oregon
    Well what i was told by the mechanic at the japanese specialist shop that if its been ran on synthentic then you dont want to switch to a thicker base. I had used just some regular 5w-30 when i first got my sub:e and it ran hard could make some akward smells. drained my oil, refilled with synthetic, shes running perfectly. That and i used a bottle of 104 high octane boost fuel injecter cleaner
    May 2012
    Bat country, Nevada
    Sounds like I need to go synthetic then. Because when I get on it to pass someone it sometimes get a werid smell with it.
    With all respect I see absolutely zero logic in any of this, sorry.
    Registered User kornkid21792's Avatar
    Jul 2011
    billings mt
    Dec 2011
    Pottstown PA
    i belive thats a myth,you can switch in between syn and conventional. if you use high mileage that swells your seals so id never use high mileage oil in mine. but ive switched types in my cars before. some people even make their own blend of 5050 oils
    doa
    doa is offline
    Sep 2011
    This is absolutely normal, go listen to any video anywhere of any subaru even the newer ones and they sound just like that.(newer models are a bit quieter) Mine is even louder than that. Anyone who disagrees has obviously never opened their hood while the engine was running.
    Jun 2012
    PDX,Oregon
    lol i didnt say any of you guys were wrong or that i was right. All i stated was what i was told from an experienced and respected mechanic.........people get ****y on these sites lol
