Results 1 to 7 of 7
This is a discussion on exhaust noise within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello, just installed a catted invidia dp and on cold starts only for the first 20 seconds or so there ...
    Jan 2011
    Mission Viejo, Ca
    exhaust noise
    Hello, just installed a catted invidia dp and on cold starts only for the first 20 seconds or so there is this loud mettalic rattling noise that does eventually go away. Just wanted to know what it is and if its normal. Thank you
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    did you tighten/cut the heat shield correctly? The bracket that hangs it after the cat to brace some of the weight did you put that on correctly? dumb questions but sometimes you miss stupid **** you know?
    Lead Wrench @ WTF Tuning, LLC
    Jan 2011
    Mission Viejo, Ca
    I had it installed at a shop so I don't know. If it were just that wouldn't the noise be constant because it does dissapate after it heats up? However the tone got a lot deeper a few days after install. Thanks for responding.
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Did they just reinstall the stock heatshield? Maybe they didn't cut it properly & its hitting the downpipe.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Registered User Mitch89's Avatar
    Oct 2011
    Bristol Tn
    Mine is actually doing the same thing after installing the same downpipe.. But i can see where anything is hitting or rattling..so id love to get any info on this as well..
    Jan 2011
    Mission Viejo, Ca
    Just talked to my install guy and he did cut it to go around dp but also said the heat shield is probably touching the dp and might need a little more cutting. So you guys were right, thanks for the feedback.
    Dec 2004
    Your Mommas
    Anytime
