Engine Idle Tapping 06 WRX
Results 1 to 15 of 19
This is a discussion on Engine Idle Tapping 06 WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello, I have a 06 WRX Limited with only a K&N filter and 100k miles. I started hearing a clicking ...
    Jun 2012
    Colorado
    Hello,
    I have a 06 WRX Limited with only a K&N filter and 100k miles. I started hearing a clicking sound. Attached is a link to the video from outside and then inside the car.
    WRX Engine noise - YouTube
    Oil was changed about 500 miles ago. Jiffy Lube said it was a quart low about 5000 miles between changes.
    I use Super Unleaded gasoline.
    I am the original owner, and do not race this car.
    Sound started between the last 2 oil changes.
    The sound is present when warmed up and when cold.
    Any help would be greatly appreciated.
    Thanks!
    Jan 2005
    Eh, whaaaaa?
    It could be my crappy work speakers, but I'm not hearing anything out of the normal WRX ticking...
    Cody
    Banned for Ageism 96accord's Avatar
    Mar 2007
    Baltimore, Maryland
    Quote Originally Posted by Anub1s View Post
    I was thinking the same thing... It sounded louder to me because of my headset...
    Jun 2012
    Colorado
    Thanks for the quick replies!
    It seemed to get a lot louder than it was before. I never was able to hear it in the cabin and then one day my gf and I noticed it after parking in the garage.
    Jan 2005
    Eh, whaaaaa?
    It could be that you're just noticing it more than you were before. Parking in a garge allows you to hear a lot more than when you park outside.
    If the noise gets worse or is accompanied by another type of sound, then it would probably be time to start worrying, but for now I personally don't hear anything abnormal and so wouldn't worry much so long as the car still drives fine.
    Cody
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Sound is normal. PLEASE, stop letting Jiffy Lube change your oil.
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    My car clicks like a mofo. If you upgrade your motor mounts it's even worse lol
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
    Mar 2007
    Baltimore, Maryland
    Quote Originally Posted by lokey View Post
    ^ This!!!
    Apr 2007
    8000' up in Colorado
    +5 million to staying away from Jiffy Lube. And you need to be checking your oil regularly and topping it off. A quart low is almost 25% less than your car should have!
    Scott
    doa
    doa is offline
    Sep 2011
    Sounds just like mine. Perfectly normal.
    May 2012
    Bat country, Nevada
    Thank god, I just bought a 2005 with 100k on it and I heard it and thought I may have spun one of those dreaded bearings.
    Mar 2007
    Baltimore, Maryland
    According to Wiki (in ref boxer engines): "Boxer engines (and flat engines in general) tend to be noisier than other common engines for both intrinsic and other reasons, e.g., in cars, valve clatter from under the hood is not damped by large air filters and other components."
    Jun 2012
    Colorado
    It is still running good and getting 26 mpg so nothing major can be wrong. Thanks for all the insight.
    Oct 2009
    I have a 2006 WRX and it just started making the same noise. There is no doubt something is different.
    Not overly loud but noticeable if you pay any attention to your ride. Mine almost sounds like a exhaust leak or maybe similar to a diesel. The noise seems to be coming from the drivers side, hot or cold, lower RPM, and may idle a bit sluggish.
    My WRX is all stock, 110K, Mobil 1 extended performance oil, and no engine lights. In trouble shooting I replaced the timing belt, tensioner, idlers, AC belt, and alternator belt. Next I will change the spark plugs with hopes that it is missing or a plug loosened up. I also remover the exhaust shrouds and see witness of leaks. My next thought is weather or not the AVS valve timing could be sticking or doing something funky.
    It may not have anything to do with it, but at my new job I have been letting my car idle for 20-30. I know that this can be bad but I didn't think it could cause symptoms like this. The noise started about this time. Not to mention, the weather is much hotter than usual this summer in Michigan.
    Jun 2012
    Colorado
    I know mine is louder than it was before. I really cannot tell what it is. I don't seem to have any performance issues or gas mileage issues. So I have just been letting it ride and hopefully nothing breaks. I will mention it to the dealer when I get my timing belt replaced. Maybe they will have some brilliant idea.
    I did get the belt tensioner adjuster replaced after I broke it trying to fix an A/C squeal turning on the A/C. Dealer fixed that for 140 bucks.
