Axle, tie rod ends, steering, suspension, debris, and maybe even in that order.
This is a discussion on Pop/Clunk sound coming from front of car when starting from a stop within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just started to notice this on my 2006 WRX. Sometimes when I start from a stop at a stop ...
I just started to notice this on my 2006 WRX. Sometimes when I start from a stop at a stop sign for example once I give the car gas and I start moving I hear a slight pop/clunk sound from the front end. It doesn't always do this. It's very intermittent. If I stop at 10 stop signs I will probably only do it once. I have not noticed it between gears or down shifting, just starting from a stop. I can slightly feel it on the floor boards. Where should I start looking?
Thanks,
Zach
Greg
www.modmeets.com
ProTuned Stage 3 '11 WRX Ltd HB (SWP) ~ 342 awhp 399 ft-lb tq on E85
Mods Blog Post
Friends don't let friends drive Mitsubishis.
Axle replacement is not 'maintenance'. I'm not trying to be a smartass. I'm just trying to help you troubleshoot without actually seeing anything. Is there more to this story? Could you get the car up and post some pics?
Greg
www.modmeets.com
Mods Blog Post
There is no reason for axles to clunk. They are not a wear item. If you did not replace the axles with authentic parts that may be part of the issue.
OK that's good. Then check everything else above.
