Results 1 to 9 of 9
This is a discussion on Timing belt sliding back off pulleys within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I replaced the full timing belt setup on my 02 WRX with a Gates kit a few weeks ago - ...
    Jul 2011
    Allentown, PA
    I replaced the full timing belt setup on my 02 WRX with a Gates kit a few weeks ago - belt, idlers, water pump and tensioner. everything went back together fine and has been running good, but I removed the cover and found that the belt has slid back and is rubbing against the back cover. Its starting to wear on the belt, and there's black soot everywhere. Any guesses as to why this is happening or how to fix it. I didn't mess with the belt guides so could it be that? btw I'm going to be getting another belt then
    Did you pull the pin on the tensioner? Did you forget the lower small last pulley? The guides and belt should never meet anyway as far as I know.
    Jul 2011
    Allentown, PA
    Yes, and No. I think im going to take everything off and start fresh. Could the torque of the idlers be affecting it?
    I do not think so and am baffled as to why this could be happening. In at least one of the how to threads here though all the torques are posted.
    The one value that might I suppose affect it is the torque for the tensioner, and from memory that's lower than the others. Check the values and I guess check the parts to see you have the right belt?
    Registered User Ryouko's Avatar
    Mar 2012
    South Jersey
    This happened to me a few months ago after I did my timing belt, but the cause was obvious. I pulled off that front black cover and found the soot from it rubbing against the cover. The bolt that holds the tensioner on was sheared and the car gods were holding it in place until I got home.
    No bueno.
    That was obvious though, so I'd say check all your pulleys and make sure none of them are sheared. Maybe one of them is cross threaded and holding the belt at an angle? I'm just throwing out ideas now. Good luck.
    Jul 2011
    Allentown, PA
    Quote Originally Posted by Ryouko View Post
    No bueno.
    you got lucky with that one, Ill be sure to check out all the bolt when I get her apart later this week
    So what led either of you to remove the cover, was there noise or?
    Jul 2011
    Allentown, PA
    Had a whining noise after i changed the belt, assumed it was just because i got some coolant on it while i was changing it. It was only audible at idle, so after a couple days i pulled off the right cover and found that black crap all over
    I see, makes sense.
