Results 1 to 10 of 10
This is a discussion on I hit the gas and the RPMs go up but acceleration does not. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Well I obviously have a problem here but I don't know what it is so I'd like some advice please. ...
    Jun 2009
    Little Rock, AR
    Unhappy I hit the gas and the RPMs go up but acceleration does not.
    Well I obviously have a problem here but I don't know what it is so I'd like some advice please. This has happened to me twice now while on the interstate. I have a 2002 WRX 190k miles stock that has had a few replacements over the years: fuel pump, radiator. I downshift (to 3rd or 4th) to accelerate and my RPMs shoot way up 5-6k but I'm not getting much acceleration. My tires aren't spinning either. What could this be?
    Thanks
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    You probably need a new clutch
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Registered User Hung_Wei_Lo's Avatar
    Jun 2012
    Quote Originally Posted by wrxtreme06 View Post
    +1 without actually driving your car and experiencing it myself, that's what my first guess would be as well.
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    clutch
    Jun 2009
    Little Rock, AR
    Can't say I'm happy to hear this but I did expect it. I'm just glad nobody said transmission.
    Cheeky Bastage! spirited09wrx's Avatar
    Oct 2009
    Dirty Jerz
    +1 to the clutch
    Zach
    Teh Intern @ WTF Tuning, LLC
    2009 WRB Subaru Wrx Sedan: WTF Tuning Stg2
    Stink eye Mob #287
    N.E.R.D. #43252003274489856000 (the total number of configurations of the Rubik cube)
    "It's not turbo-lag, it's foreplay"
    Jun 2006
    Nor Cal
    Clutch job taken to a shop should run around $1400. The clutch disc and flywheel need to be replaced. Parts costs alone are around $750. I recommend OEM flywheel and EXedy OEM clutch disc
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    flywheel doesn't actually have to be replaced - you can get away with a resurface (or, most of the time, without). Only if you have deeply embedded hotspots, or if you want a lightweight flywheel, should you replace that.
    The OEM replacement clutch from Exedy is what you want - it's the OEM clutch but cheaper. Parts cost: around $200. Labor is the tough one on this - you need to drop the trans, which is not easy. Let a pro do it - it'll cost you.
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Jun 2006
    Nor Cal
    Quote Originally Posted by poly_poly-man View Post
    The stock dual mass is not resurfaceable, so why risk it?
    Jul 2004
    Seattle, WA
    Quote Originally Posted by 06wrx4me View Post
    I agree, Subaru says not to resurface it. Replace it, if need be.
