Results 1 to 3 of 3
This is a discussion on P0031 Code within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Heated Oxygen Sensor Heater Control Circuit Low (Bank 1 Sensor 1). Finally a code popped up for the wagon. This ...
    Registered User scoobaru03's Avatar
    Dec 2009
    Davidsonville, Maryland
    P0031 Code
    Heated Oxygen Sensor Heater Control Circuit Low (Bank 1 Sensor 1). Finally a code popped up for the wagon. This is the only one on. Now Would Bank 1 be the right side of the engine and sensor 1 be the sensor in the right side header?
    2003 Impreza WRX Sport Wagon
    "I wouldn't want to belong to a club that would have me as a member." - Groucho Marx
    Is it fast? I don't even know if its street legal. O.o (IROC-Z)
    There is only one Bank.
    The sensor to which you refer is the front sensor; side isn't relevant as there's nothing on the other side. See this thread and follow the links therein:
    O2 Sensor :(
    Dec 2009
    yea strange thing happened when i was doing the diag i got 14.XX volts on power on the the harness side of the connecter for the A/F sensor. Then i checked the ground side and it dropped to about 10.XX. i figured 4 volts was alot of voltage to drop. I figured i had high resistance somewhere in the wire between the computer and the connector but it checked out ok. Long story short the A/F sensor was open so i get to spend some more money..yay...but i was wondering if anyone knew why the ground side would drop about 4 volts like that with normal resistance.
