Revvs extremely high when engine hot
Results 1 to 9 of 9
This is a discussion on Revvs extremely high when engine hot within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi. Mods done: Fidanza flywheel TIAL 50mm Blow-off Denso Iridium IK20 TGV Delete Grimmspeed Electronic Boost Control Solenoid Silicone induction ...
    Mar 2012
    Estonia | Tallinn
    Hi.
    Mods done:
    Fidanza flywheel
    TIAL 50mm Blow-off
    Denso Iridium IK20
    TGV Delete
    Silicone induction
    Cold air intake
    New camshast sensor
    Problem: When pushing the pedal and engine is more than totally warmed up, revvs are going up to 2500-4000 (and will be sustained on it), and don't want to go down. Doesen't matter if Im idle, or driving in gears. After some normal driving it goes back normal (15 minutes or so). It seems that some kind of sensor or IACV is going crazy, or what do you think?
    Apr 2007
    8000' up in Colorado
    You need to list your year and mileage before anyone can help.
    What tune are you running? What is special about the camshaft sensor versus a stock one?
    Scott
    Mar 2012
    Estonia | Tallinn
    Sorry, forget it. It's 12/2001 WRX (bugeye), EJ205 engine, 240k km on it.
    Nothing special about the camshaft sensor, for some reason last owner changed it.
    Tune was done by last owner using tactrix openport, don't know how much he changed the settings, but turbo pressure, air/fuel have been changed.
    Moderator Donkey's Avatar
    Da boonies,Va
    It's either the cruise control unit/cable (common problem),your actual throttle cable or your IAC valve needs cleaning/replaced.
    2002 FORESTER S
    1998 FORESTER S
    Mar 2012
    Estonia | Tallinn
    Can't be the the cruise control, because I don't have it. I also assume the IAC, because it has shown trouble before. I just cleaned it month ago, but used old gasget, because it was in new condition and shape. May it be, that there is a air leak in the IAC when it's going hot, and maybe replacing gasget may help?
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    It sounds like your IAC valve. Or check your throttle plate to make sure it's closing properly.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Mar 2012
    Estonia | Tallinn
    Your right. Seems that the throttle does not close properly. I don't know why, but it happens only when engine is hot. I oped up the throttle cable and oiled it a bit, but the proble still occurs. Will open up the throttle system, clean it, and hope it helps.
    If you don't have a cc cable check the linkage anyway and the main throttle cable, then think ISC IMO.
    Sorry should read IAC.
