Edit, I suck at reading obviously. Have you checked the battery voltage when you turn the key?
This is a discussion on 02 won't start without roughing it up within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So, my '02 wagon just started this behavior. It won't turnover. I put in the key, full lights. Turn the ...
So, my '02 wagon just started this behavior. It won't turnover. I put in the key, full lights. Turn the key to start and nothing happens. Can't jump start with cables but, it will push start. Any ideas?
-mx
Check the starter relay and any related fuses as well.
The voltage gauge remains the same when running or turning the key. I will look at the relay and fuses.
I would think it has to be a bad relay, fuse, or bad starter. Those are the usual suspects. If you find the starter relay and there are any relays around it that are just like it, swap the relays and see if that makes a difference.
Also, if you can get at the starter, give it a few love taps with a wrench or hammer and see if that helps.
Edit: Possibly a bad clutch switch as well. The one the pedal hits when you push the clutch pedal down. Pretty sure that is part of the starting circuit.
I wondered about the clutch switch. How do you check that?
If you unplug it I think you can jump the connector with a fuse or a piece of wire. I would try a fuse first. if you don't have a spare pull one from the fuse box that isn't necessary for the car to Run. if you do jump it make sure the car is in neutral before you try and start it or it will lunge forwards on you.
So, strangely, it started right up when I went out from work. Then I drove home and stopped to get the mail and it did it again at first and then on the second attempt it started. This is weird.
-mx
Did you check the clutch switch? Check the grounds as well.
Starters usually go intermittently like that.
when you go to start it, listen closely, do you hear a clicking sound. If not, your starter solenoid is not engaging.
Update:
I took the battery in to be tested and it was apparently bad so, I bought a new one. After I put it in, when I turn the key all the power shuts down. This is getting more strange.
-mx
