Results 1 to 15 of 15
This is a discussion on still smoking under the hood within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I'm getting frustrated now. Whenever pressure under the engine occurs as in driving around, when I come to a ...
    Oct 2011
    jacksonville arkansas
    So I'm getting frustrated now. Whenever pressure under the engine occurs as in driving around, when I come to a stop, under my hood smokes. I changed all the lines to the turbo, and I changed my valve cover gasket, so now I don't know what to do next. I'm dreading it to be a head gasket... But if it is, ill find a way to change it. Any help on what it could still be? My coolent lines are also fine.
    Registered User deepseastetson's Avatar
    Jan 2012
    Wilmington NC
    what year? I had the same exact problem. Pray its a CV boot flinging grease on the DP
    Here is the thread of my story Smoke from hood scoop
    Oct 2011
    It is an 02. I do see a bunch of either gunked up oil, or grease on the manifold under the turbo. What do u think?
    Jan 2012
    Wilmington NC
    I also have an 02. I had the same exact symptoms. If you can get under the car look around for the oil leak. Mine had oil coming from the head gasket on the passenger side. it gets on the DP witch is super hot and burns creating the smoke. if its an internal leak then you will see coolant in the oil etc. but if its an external leak then you wont notice the oil looking like a vanilla milkshake. I had the dealer fix it and the motor has to come out witch is a ton of labor charges. about 1600-1700 bucks. sounds to me like thats what it is, thats what happened to mine.
    Oct 2011
    I'm not to worried about the cost of labor. I got a buddy who just got stationed where I'm at and he has an 07 STI that he just ripped the engine out of to check his piston rings. So I'm gonna check the cv boot soon. And then check the gasket. It's not smoking anywhere as much as yours did in the video, bit deffinatly from the same area. I appreciate the help and when I get around to it ill keep you posted. Thanks man.
    Jan 2012
    Wilmington NC
    Your lucky! I am stationed in an area where i dont have anyone that can help me so i had to use the dealer. They didnt even do a good job in my opinion and they still have it. its been like 2 weeks. If your buddy can help you than that is awesome. wish someone could have helped me with mine lol
    Oct 2011
    This place is ok. The people I work with though are awesome. So yeah. I'll keep you posted take it easy.
    Oct 2011
    So subaru told me it turned out to be both valve cover gaskets, cam and crank seals and my oil cooler
    Gasket. Let's just hope it finally fixes it.
    Jan 2012
    Wilmington NC
    sounds like you lucked out a little. good thing you avoided the dreaded head gasket leak. How much did they quote you? make sure you check it all out when they say its done. The dealership i brought mine to did not do a good job. gave me my car back with the check engine light on! turns out the technician didnt plug the knock sensor in when he reinstalled the motor! then after having it back for 1 day my car just crapped out on the side of the road. after days of electrical troubleshooting it was a pinched wire from the motor reinstall. Seems to me like they just try to get the job done as quick as possible so they can get the next car in and charge an arm and a leg.
    Oct 2011
    Well they estimated me at 1200. Which I thought was bull. So instead, I bought the parts I needed, and me and my friend who has an 07 STI are gonna do it our selfs. He knows his way around the engine. not too hard of a job. But it only cost me $80 instead of $1200. It might not be for a couple weeks. Would u suggest doing a timing change as well even though I had one last year?
    Jan 2012
    Wilmington NC
    Nah, timing belts are good for like 120,000 miles. You should be good if it was just done last year. Yeah Subaru did my head gaskets, valve cover gaskets, rocker gaskets and 4 new plugs for 1900! And it was only like 2 or 300 bucks in parts. The rest was labor! They charge a lot for those jobs. I had no choice though, I had no means of doing the work myself.
    Oct 2011
    really? you got screwed. if they just did my 2 valve cover gaskets, it would have been 500. and the parts for those which include the valve cover gasket itself, and 2 plug seals is only $29 for one side. haha. and about the timing change. i was wondering because to get to the cam and crank seals, i have to take off the pullys. and the easiest way i hear is to actually grip them with the belt so they dont twist when you are trying to unbolt them.
    Jan 2012
    Wilmington NC
    The big difference between the work you need and what i had done is the head gaskets. that is one of the most expensive repairs. If i didnt have a external head gasket leak at it was just the valve covers i would have had to spend a lot less money. Damn you head gaskets!! for the timing belt, if your are going to grip it or in any way damage it then maybe replace it since you will already be in there. you dont want that belt to fail, it will cause damage to your motor. you can get a Gates racing belt for just over 100 bucks.
    Oct 2011
    Yeah. I was looking at a whole gates racing set for 300. I'll probably just go ahead and do that. Like I said. When I get time my bud and I will get in there and when we do. I'll keep you posted. Thanks
    Jan 2012
    Wilmington NC
    Cool! Good luck man.
