Results 1 to 12 of 12
This is a discussion on engine tends to bog down within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi, I got a problem. I have an 02 wrx, and it doesn't seem to be running like it should. ...
    Oct 2011
    jacksonville arkansas
    Hi, I got a problem. I have an 02 wrx, and it doesn't seem to be running like it should. I don't have much done to it, just a tbe and bov. But sitting at idle, it tends to bog a little bit and when I step on the gas to get going, it does the same as if it just doesn't wanna get going. But after that it doesn't bog until I get to a stop and of almost stalls. Rpms drop to almost 0. It also feels like I got some loss of boost. The air intake and maf is fine, turbo is not leaking either. Can anybody help me out please? Is appreciate it.
    Moderator Donkey's Avatar
    Da boonies
    It's pobably the BOV. What type is it?
    2002 FORESTER S
    1998 FORESTER S
    Mt. Laurel, NJ
    I'd have to second this.
    Oct 2011
    Turbo XS. I have heard that it might make the car run lean. Any suggestions on a good not too expensive bov?
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    I would try to find a stock bypass valve! That would work. Look on nasioc.
    <-------- Taylor Swift.
    99.5 Jetta...I hear they make 90 to the wheels....
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    Da boonies
    Quote Originally Posted by heavymetal21192 View Post
    Turbo XS what? Recirculating,50/50,full atmospheric?? Read this:
    ---- BOV / Blow Off Valve Information ---
    2002 FORESTER S
    1998 FORESTER S
    Oct 2011
    It full atmospheric. I bought the car with the bov on it. And it runs perfectly fo.e when its cold and wet out. But I'm stationed out in Arkansas so its hot and muggy. And it doesn't seem to like it that much. What do you suggest? Should I get the stock bypass valve?
    Oct 2011
    I am going to get it tuned here very soon though.
    Mt. Laurel, NJ
    Tune or not, you don't need it. Find a stock one, sell the TurboXS. You'll recoup money on it.
    Oct 2011
    Alright man. I appreciate it. I'll jump on that.
    Oct 2011
    Now just so I know. Why is my car running this way cuz of the bov? And of I het another aftermarket one, what would you prefer? It's just hard to find them stock where I'm at.
    Oct 2003
    New Jersey
    Seen a few posts on this issue -- idle just drops to zero/engine shuts off, often when decelerating or at a stop light. Especially scary when you're in motion. Way beyond my abilities so brought it to my mechanic and he completely cleaned out the throttle body. Lots of gunk in there apparently (140k miles). So far running like a charm...
    In the other posts, someone else cleaned out the IACV and others suggested to reset the ECU afterwards.
    Hope that helps...
