Results 1 to 6 of 6
This is a discussion on MAF sensor? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Do you have to have a MAF sensor or can I cut it out with an after market ECU?...
    May 2012
    Question MAF sensor?
    Both; you will need a way of measuring air. You can go to a MAP setup if you insist.
    May 2012
    My plan at this stage is filter, (exsisting bonnet scoop hole enlarged), silicon joiner straight to turbo, short path cold air, my car is heavily modified and I am running out of under bonnet space
    Apr 2007
    8000' up in Colorado
    What has your tuner told you? Because if you don't have somebody that can design a map for the setup, there's not much point in going any further with this idea.
    Scott
    Texas, United States
    You can run speed density, if that's how you wish to be tuned.
    Moderator Donkey's Avatar
    Da boonies
    Depends on the aftermarket ECU. Your question is pretty generalized. You can run speed density,if the Engine Management you use allows it,but you will need to install an IAT sensor. The stock IAT sensor is combined with the MAF sensor unit. It's the amber bulb on the side.
    2002 FORESTER S
    1998 FORESTER S
