Engine Tranny or Exhaust?
Results 1 to 4 of 4
This is a discussion on Engine Tranny or Exhaust? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a stock 02 WRX and something is going on that I do not like. We starting from a ...
    Apr 2012
    NV
    I have a stock 02 WRX and something is going on that I do not like. We starting from a stop in 1st my car almost seems keep the clutch engaged longer than I let it. Then the engine will rev up a little and finally It will feel like It is really in gear. And recently while driving if I'm in say 4th going around 40 and I press on the gas my engine will rev until red line (unless I stop it) and no power will get to the wheels almost as if I were holding the clutch down and pressing on the gas, then the RPMs will drop and I'll finally start to feel some forward momentum. My boost gauge will read around 5 to 10 psi depending on how hard I press on the gas while the engine is revving.
    Recently as well when I stop the car and turn it off and get out I can smell something burning from under the car.
    So not sure if my clutch is burnt up, My tranny is going, or my engine/turbo/exhaust is burning.
    When shifting though everything is smooth through all of the gears no grinding, no jumping, no not being able to put it in gear.
    Yes I still have the crapy stock exhaust and I will be replacing the whole system in the future.
    Not sure if it is one thing or a combination of all three.
    The clutch is slipping. Time to replace the clutch.
    Apr 2012
    NV
    Thank you. I had a feeling thats what it was. Just had to make sure to cover all the bases. Thanks again
    If you replace the clutch consider the Exedy OEM equivalent, people seem happy with that. Also, people can sometimes get misfire codes with a lighter flywheel, so consider keeping things stock or stock-equivalent in my view. Good luck.
