Results 1 to 5 of 5
This is a discussion on oil change within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Im just curious. Ive been using Pennzoil platinum in my wrx since i got it last year, and forever when ...
    Registered User foxhound's Avatar
    Feb 2005
    Buffalo
    oil change
    Im just curious. Ive been using Pennzoil platinum in my wrx since i got it last year, and forever when i had my 06 legacy gt. I was using Mobile 1 but with my legacy it tripped an engine code because it would cause an oil return valve to stick open. I was just wondering what motor oil are you using and why?
    ??What oil should I use??
    Without a UOA, advice is meaningless. Like with base maps, every car will react differently, so you should invest in a UOA yourself to see how your car reacts to the oil you're using. Get a kit from Blackstone for your next change, and see what's going on with your current oil, then consider switching.
    Personally, I just made the switch over to Rotella T6, and am waiting to do a UOA at this oil change (I wanted to wait until I went through two changes before shipping a sample out).
    Feb 2005
    Buffalo
    im not asking for advice, i know what kind of oil i use. im just curious what kind other people are using
    Quote Originally Posted by foxhound View Post
    Whichever 5W-40 fleet or diesel oil is cheapest.
    Texas, United States
    I use Rotella T6 5w-40.. although I'm about to start adding a zinc additive to it every change since they recently changed their formula.
