Rear diff or rear axle?!?!?! please help.
Results 1 to 15 of 26
This is a discussion on Rear diff or rear axle?!?!?! please help. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Well tonight unfortunately, it was one of those nights where I did not go with my gut feeling. I went ...
    Oct 2010
    Well tonight unfortunately, it was one of those nights where I did not go with my gut feeling. I went ahead and launched my car at around 5k and right away I heard a snap like noise. I then got out of the car and looked under, noticed no leaks and heard no weird noises. As I went to drive the car, it felt like it was struggling to move. The rpms would go up, but the car would move slowly. For example, while in first gear, I brought the rpms to around 3k and I was just driving around at like 4mph.
    -- This is a video I got my brother to record during the slow drive home. sigh. (I was in first gear in the video)
    #LessonLearnedTheHardWay
    thanks for the help!!!
    Do the revs rise freely yet the car doesn't move proportionally?
    Oct 2010
    Yes your right......the speedo will say im doing 60mph when im probably just doing 9-15mph.
    The speedo moves freely and not the tach? Never seen that before.
    Jan 2005
    Eh, whaaaaa?
    Sounds like a blown rear diff to me. I wonder if the free spin in the rear (and the center diffs inability to compensate much) is causing it to read speed differently.
    Cody
    Because of the speed sensor connection on the gearbox, eh? Seems reasonable. Interesting.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by Anub1s View Post
    Seems plausible to me as well. If that's the case, then OP, do NOT drive the car anywhere until you get it fixed. Flatbed it to the dealer if you have to, or replace the diff yourself. If you did blow the rear diff, then your car is essentially FWD now, and you'll blow up your center diff (if it isn't toast already) if you drive like this. It's much cheaper to replace the rear diff then have to do the whole drivetrain.
    Couple more things to check with the car stopped:
    1. Can you shift smoothly into all gears with the car idling, clutch in?
    2. Any sign of clutch slippage?
    2007 Outback 3.0R wagon
    Oct 2010
    Quote Originally Posted by Rambo View Post
    1. Yes I can shift smoothly into all gears with the car idling, clutch in.
    2. As for the clutch slippage, I'm not noticing any clutch slippage.
    -- smh, really it might be the rear diff. I just bought that rear diff back in the beginning of march (last month) for my 6MT trans swap. The rear diff is a R160 LSD with 3.90 ratio.
    *fingers still crossed for the problem to be a rear axle, even though now I believe is very unlikely.
    Dec 2007
    sounds as though the axle is not completely inserted into the rear diff.
    Oct 2005
    Late Devonian
    Does the drive shaft appear to be connected?
    Also, it is easy to look at and twist an axle and determine if it is broken.
    Oct 2010
    Now I'm a bit confused on what it can be, when ever i have to move the car to the other side of the street (for street cleaner :/) I notice there will be a weird squeak whenever the car beings to move. So I went ahead and did a youtube search, and found a video that sounds exactly like my car except the car is not moving.
    Subaru wrx Clutch Squeak - YouTube
    I just don't want to go off and buy the wrong part.
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Just guessing here: try to lift the rear off the ground, see if you can turn the wheels by hand. If you can turn either wheel without the other turning, your shaft(s) are not engaged. If one wheels makes the other turn backwars, the diff is working and the axles are in. Then the input to diff is not there...
    Off course, no hand brake. And make sure the front wheels can not roll anywhere... (!)(no oopsies here!)
    Oct 2010
    ^^ thanks will try this when I get home.....
    Apr 2007
    8000' up in Colorado
    Yup I totally agree. Because of the speed sensor being on the tranny, that means the only part in the drivetrain aft of the tranny that could cause that behavior is the diff. Time for a new one! Yet another poor soul learns why it's not a good idea to launch these cars...
    Scott
    Oct 2005
    Late Devonian
    I'm curious as to why you are looking for speculation on the issue vs. you just crawling under there and looking for damage?
    Jacking it up is also a good idea, just don't crawl under there unless you have it up safely on stands.
