Perhaps the next thing to try would be to get a friend and to both try to turn the rear wheels (together, same direction when it's on the jackstands)? I assume that since this is all wheel drive that you should not be able to turn the rear wheels (when the front is on the ground) if the drivetrain aft of the center differential is in good working order. If they turn then the problem is at or after the center differential... (I'm not too familiar with the mechanics of this car, but does my logic make sense?)
..although, I suppose the fact that the rear diff spins the wheels in opposite directions kinda confirms that it is solidly connected to the center diff.. right?
LinkBack URL
About LinkBacks
