Oil use has not stabilized. Check regularly, note how much is used, and see what happens as the motor continues to break in. Since you don't know what was missing you can't say if it's abnormal or not. I'd not worry, but I'd watch it.
This is a discussion on Is this normal? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I know Subaru says the first oil change at 7500 although I got a little weary when I hit ...
So I know Subaru says the first oil change at 7500 although I got a little weary when I hit 5700 and decided to call the dealer. The dealer recommended 3700 and suggested I come in ASAP which I did. After it was done I pick the car up and notice on the receipt a note from the tech - OIL LEVEL WAS LOW, RECOMMENDED ON ALL TURBO MODELS TO CHECK AND TOP OFF ENGINE OIL LEVEL IN BETWEEN CHANGES- my wife had a 13 year corolla with 160,000 miles on it that we added oil every 2 weeks but 2012 car? It's my daily driver and most of my drive is in rush hour, I like to push it once and awhile but no redlining it or bringing it to the track. Is this normal? Or could there be something wrong with the car? Feedback is appreciated
make it a habit of checking the oil at least every 1000 miles just to see how its behaving. i take it you didn't check it at all for 5700 miles. just take note of how much is in there now and check it often.
2011 WRX Limited w/ Nav, Tach Motor Works & JR Tuned - Stage 2+ ~ 306 awhp 328 ft/lbs @ 19psi
AEM Intake, Process West TMIC, GFB Respons BOV, Invidia Q300 Turboback, Grimmspeed EBCS
AEM Wideband & Boost Gauges, SMY Cluster, SPT Short Throw Shifter/Bushing, Anarchy Motive Shift Knob, 30% Tint
Going to keep an eye on it just makes me nervous that they noticed it was low, I'm sure they don't measure it when they drain it so I'm thinking it was so low not much came out. It may be good advice from them although it would have been more helpful info before I took it off the lot
I seem to recall the owner's manual instructs that the oil be checked at every fuel fill or something to that effect.
Thanks need to read it closer, did you experience any loss initially ?
I seem to recall I did, yes. I would check weekly or so and did my first change at 3K, and it'd been half a L down at that point I think. After 20K on the motor it stabilized to 250 ml - 500 ml per 5K, then went up a bit more as the motor aged. Now at 120K it's around 750K per 5K oil drain interval or so, depending on what oil I use and how it's driven.
K thanks for the response appreciated
i wouldnt worry too much about it until you actually start monitoring it. i havent had to top off yet and im already at 30k miles. i did keep a close eye on it for a while, but it never made it below the halfway mark on the dipstick at any point, and i've gone up to 5k before a change. i did however change the oil around 3k since i was at the dealer already getting a fuel door spring replaced.
Be happy you brought it in early! (This being my first car, and I was learning, etc. don't worry i got a ton of abuse on this forum for the mistakes ive made as a dumb teenager, but ive since grown up) My dealer delivered my car with 27 miles on the clock (brandy new) and the guy who delivered it said, "bring it in around 7k-7,500 and they will do a real quick check up on it then send you on your way. well, 6k miles roles along and i sound like marbles in a tin can going down the road. I call my dealership, send it in, and sure enough had a blown motor. They realized this was not due to any fault on my part (besides not checking the oil, although i was instructed, and had a sticker on the window which read, 'next service 7,500') They replaced my motor and whatever else had gone with it under warrantee. When i picked it up with the new motor, I told them I would see them in 1k miles, then in 3k, then i would change it every 6k from then on. I can't tell you how far my heart dropped hearing that blown motor run, I thought my dad would sell the car and buy me a smart for two (I know, a kid shouldnt have a sports car as is, but I come from a family whos real into cars)
forgot to mention, when the dealership got the car, it only had a half qt of oil in it. I now check the oil every single time I gas up
Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
holy crap where did all your oil go?
Once you use up enough to damage the motor, the rest can disappear rapidly.
too bad our cars dont have an oil level sensor like my BMWs did.
i remember i had to fill my 92 525i with a quart of oil every 2500 miles
