Are you hearing the squeaking noise on a same rode? It might be from a sewer cap you are stepping on.![]()
This is a discussion on squeaking noise from the front left wheel!!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i own a wrx sti v7 2000 andThis noise has only just started the other day then it went away ...
i own a wrx sti v7 2000 andThis noise has only just started the other day then it went away but came back, when ever i turn right you can here this squeaking noisebut then turn left and it goes away ??? i have taken the wheel off and adjusted the wheel bearing checked out the caliper and roter but still it makes the noise, any ideas i have owned the car for about 3 months ??
Power steering?
How many miles on the car? Does it have the problem only at lower speeds, or at higher speeds too? How exactly did you "adjust the wheel bearing"?
Scott
150,000 only at lower speeds like 20-60 km then it goes away
like this morning it went then 5minutes it just came back
