Hmm... One thing you might consider is to remove the belt to confirm the noise, then replace the belt with an authentic new belt and go to the correct tension. If it's the belt, the noise will go away. If it's not the belt then start suspecting the pump I suppose. It's the kind of thing a good mechanic can diagnose much better than remotely over the internet.
LinkBack URL
About LinkBacks
