Results 1 to 4 of 4
This is a discussion on overheating within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; im having an overheating problem on my 2001 ive changed the radiator as it was leaking and the thermostat it ...
    Apr 2012
    overheating
    im having an overheating problem on my 2001 ive changed the radiator as it was leaking and the thermostat it seems to get warm and fill the expantion tank and not return to the header tank and the bottom hose stays cold can any one help as im ripping my hair out with it ?
    It started after you changed the radiator? You need to burp the system. One way is here:
    Overheating After Rad. & Timing Belt Replacement
    but there are others. Burp the system repeatedly and when you are sure it's done, burp it all over again because it's not.
    Apr 2012
    thanks very much ill try that
    Moderator Donkey's Avatar
    Da boonies
    Yup.........and make sure the car is on level ground so that the turbo coolant expansion tank is the highest point in the cooling system.
    2002 FORESTER S
    1998 FORESTER S
