Need help - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
This is a discussion on Need help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; You said that the AP had a Stage 2 map that "the guy you bought it off of put on ...
    Palmyra, NJ
    You said that the AP had a Stage 2 map that "the guy you bought it off of put on it"...do you know if it's a base stage 2 map or if it was some sort of a protune? If it's a protune, it might not work the best for your car.
    Jan 2012
    I am pretty sure its a base map, he did say he had never had an issue with it till recently and that hes had the map on there for a year. Is there a way to find out if it is a protune or a base for sure.
    Palmyra, NJ
    Quote Originally Posted by cubano View Post
    not sure on the V1 APs...datalog your car? That should tell you...
  6. #19
    Oct 2005
    Late Devonian
    As said above, the car can probably be logged with the V1 cable and Romraider. You may even be able to save a copy of the map with ECUflash to look directly at the rom (don't think so though). I'd assume a protune would have a different boost target than cobb, or other obvious differences with the timing or fuel targets we could see in the logs.
    Also as said above, a log will tell you a lot more than us guessing at things.
    Datalogging with Romraider:
    Regardless, you should be cleaning and checking your MAF and for intake leaks and boost control system leaks at least (we don't call it MAS).
  7. #20
    Jan 2012
    Alright so here it is I downloaded romraider and this is the log that i did with the MAF is connected on this see what you guys think
    romraiderlog_20120404_222735 - Sheet 1.pdf
    I have a few more if anyone is interested but hte files are too big to put on here.
  8. #21
    RomRaider • View topic - How To: Make useful data logs
    Resident Tuner @ WTF Tuning
  9. #22
    Oct 2005
    Late Devonian
    Your A/F correction is maxed out at 25. That means it is having to add a bunch of fuel for unaccounted air, or your MAF or A/F don't agree because one or the other is bad.
    This is the type of thing you would expect to see if the turbo inlet hose was torn (fairly common). It can be hard to spot if it is on the bottom at the turbo coupling.
  10. #23
    Jan 2012
    Hey guys it ended up being the MAF thanks for all the help.
  11. #24
    Oct 2005
    Late Devonian
    Glad you got it worked out & thanks for posting the solution
