Shift linkage HELP
Results 1 to 3 of 3
This is a discussion on Shift linkage HELP within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So today I was driving, I hear a snap then my shifter gets very loose. Luckily I was still able ...
    May 2011
    NJ
    Shift linkage HELP
    So today I was driving, I hear a snap then my shifter gets very loose. Luckily I was still able to find the gears and was able to drive home. When I got home I put it up on jacks to find that my shift linkage fell off of its mounting bolt. Then under closer inspection the bolt that it would mount to broke directly when the threads were leaving there no where for a nut to secure the linkage/bushings on. What is my next step? Can a mounting bracket be bought and installed? About a month prior I installed a twm short shifter and front shifter bushings. Thanks in advance for any help!
    "when the turbo spools, it's like you're in a time machine"
    May 2011
    NJ
    picture for reference. I found it with the linkage off of the post but I put it back on so I could comfortable move my car back into it's proper spot
    Registered User mexicanzero's Avatar
    Oct 2009
    Ottawa Ontario Canada
    wrx with a 5 speed right?
    go to the dealer im 90% sure that piece bolts onto the transmission
    they'll be able to find a pic and see if its a bolt on part
    for now the only thing i can really think of is to "tie" it in place with a rope or coat hangar or something?
    it was probably over torqued, just not enough to break right away so watch out next time
    -Alex
    LIVE LOUD, ROCK HARD!!@
    2003 WRX wagon 16g + 6 speed
