Results 1 to 6 of 6
This is a discussion on Water(?) draining from hose when Ac not being used within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am having an issue with puddles of water being under my car every time I back out of my ...
    Mar 2012
    Greenville, Nc
    I am having an issue with puddles of water being under my car every time I back out of my garage. I am assuming it's water at least. It's odorless and feels like water. I found the hose it is coming from (on the left side of the engine sort of towards the back) and my best guess is that it's the Ac drain hose. However... it's spring time here and I have yet to turn on my Ac. I could see it perhaps draining a little bit of water but this seems a little bit substantial. Is there anything that could be causing this that I need to worry about? Or is this just normal? I'm a new Sti owner and I'm just learning the ropes so any advice would be greatly appreciated! Thanks in advance!
    The A/C will run if the defroster is used also. If it's clear and cold, it's water and don't worry.
    Mar 2012
    Greenville, Nc
    It's been clear and warm lately. But I do believe I may have had the defrost on and just not noticed it with the windows down and all. It wasn't on high or anything and it was a decent amount of water. That's still normal you think?
    Thanks btw!!
    If the liquid is clear and cold it's water, and if it's water it's coming from the A/C drain as you suspect. Everything else on that side of the car is either coloured, viscous, warm, or combinations thereof. The defroster engages the A/C for the dehumidifying effect. I'm standing behind my theories.
    Mar 2012
    Greenville, Nc
    Cool man. Thank you much!!
    Sure, welcome.
