Results 1 to 4 of 4
This is a discussion on inconsistant boost within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello i have recently been having inconsistant boost with my 02 wrx .. mods are aem short ram intake, godspeed ...
    Registered User Rexxy2Sexxy's Avatar
    Jan 2012
    A, A
    inconsistant boost
    Hello i have recently been having inconsistant boost with my 02 wrx .. mods are aem short ram intake, godspeed turbo inlet, megan racing down and up pipe, flowmaster exhaust, and a turboxs bpv.. i am running stage 2 93 tune with 93 gas.. i was getting about 15.2 boost a week ago however my target boost still stated 16.5 .. i am now only getting around 13.4 psi and sometimes only 12.. i understand these cars are tempermental when it comes to temperature.. temps this week have been in the 50s and 60s .. i checked all my vacuum lines and reclamped everything down .. i am running out of ideas.. help please, thank you in advance.
    Pressure test to check for boost leaks?
    Registered User metaldahlberg's Avatar
    Sep 2010
    NH
    Is this always in the same gear? Do you always start a pull from the same rpm? I've noticed that I won't make the same boost in 1st as I will in 4th. It really depends on load and can even vary a bit in the same gear.
    Contributing unsolicited, worthless opinions since 9/10...
    The project I spend all my money on.... <---- Click it
    Jan 2012
    A, A
    Yea higher gears seem to generate more boost .. but lately that hasnt been the case .. it still pulls hard but im not hitting what i should be .. i have considered a presssure test but not sure how much those run
