Dealer won't replace engine after destroying it
Results 1 to 12 of 12
This is a discussion on Dealer won't replace engine after destroying it within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I recently bought my 04 sti and it was running fine. Then there was this pinging sound in the ...
    Mar 2012
    Socal
    Unhappy Dealer won't replace engine after destroying it
    So I recently bought my 04 sti and it was running fine. Then there was this pinging sound in the engine compartment so I took it to a dealer. They said that it was an internal engine failure and that the engine would need a tear down. So it was done and they came back telling me that it needed a new clutch and timing belt (not internal engine failure). So they put everything back together including new clutch, timing belt, seals, gaskets and pulleys and there was still a pinging sound. My fiance and I determined that it was from the aftermarket headers banging off the frame. So we had the dealer swap out the headers for the stock ones. No more pinging. Took the car home and the next day there was a coolant leak. Towed back to dealer and they said that it was not something that they would have touched while working on the car, which I found hard to believe but whatever. They replaced the hose for free. 700 miles later the engine seized. I took the car to another dealer this time and they told me that a piston melted inside the engine and that I would need a whole new engine. They also told me that my car only had 1/2qt of oil in it and that the previous dealer over torqued the engine when they put it back together. The car was not leaking oil. The car was not burning oil. There was no oil anywhere, including the engine apparently. There were also not engine lights on to indicate overheating or oil problems. So I called the other dealer and they said that my car lost 4.5 qts of oil from a cobb tune, down pipe, intake, and the aftermarket clutch and headers(which had already been swapped out). So essentially because the car is modified the oil just disappeared in less than 700 miles from the last time the dealership saw the car and 2600 miles from last oil change. Any comments on that one?
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Yup, sounds like a Subaru dealer.
    Lead Wrench @ WTF Tuning, LLC
    Registered N00b impretzel's Avatar
    Nov 2010
    SoCal 626
    Hoe. Lee. ****
    im at a loss for words and i cant even tell where the bs starts. Wtf you gunna do now?
    '12 STi stage 2
    Origin GT = impretzel
    Bf4
    -JJ
    Dec 2004
    Medford, Oregon
    He's gonna buy a motor and put it in because what's he going to do? Fight a million dollar dealership on a normal salary?
    Time for a build thread!
    Mar 2012
    Socal
    Wink
    Quote Originally Posted by T0rque View Post
    He's a she but aside from that im consulting with a mechanical fraud lawyer in la
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Hopefully it works out for you.
    The tune & addition of aftermarket parts was done after the dealership screwed everything up,correct?
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Oct 2011
    Santa Ana, CA
    Since you're in SoCal, would you mind posting which dealership this was?
    Mar 2012
    Socal
    Quote Originally Posted by rage-wrx View Post
    No, those were in there before and my car never ate oil until after they touched it. I'm actually back with stock header and clutch which the dealer put in for me.
    Mar 2012
    Socal
    It was southcoast subaru in costa mesa
    Registered User WRXpa's Avatar
    Jan 2012
    Philly Burbs
    Sorry to hear that man..hope it works out
    I have a low Reynolds number
    TP Stage 1 - 2012 WRX Premium 5-Door SWP
    Pics!
    Jan 2012
    What I'm guessing is when they took out your motor for a internal inspection and drained the oil out and forgot to put the oil back in and putted everything back on worry free, it's a simple mistake but could cost you an arm and a leg but hope everything goes well with you and your subie
    Feb 2012
    A, A
    Bend over and put your wallet on the counter.
