Random question of the day
Results 1 to 10 of 10
This is a discussion on Random question of the day within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Just noticed something on my '12 subie an wanted to see if this was normal. When in a gear, is ...
    Registered User Jabbathewhat's Avatar
    Dec 2011
    Pembroke Pines, FL
    Just noticed something on my '12 subie an wanted to see if this was normal. When in a gear, is it normal for the shifter to have some wiggle room from left to right or should it be solid with no movement?
    12/27/11 - Ordered
    01/16/12 - Received
    2012 WRX Hatch World Rally Blue
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    OEM bushings?There may be some wiggle.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Dec 2011
    Pembroke Pines, FL
    Yes oem bushings. All I have is kb sts. I am going to take a quick vid and see if I can post it here.
    12/27/11 - Ordered
    01/16/12 - Received
    Side-to-side play is the shift linkage bushings. Replace them with the set Turn-in Concepts offers and that will go away.
    Resident Tuner @ WTF Tuning
    Dec 2011
    Pembroke Pines, FL
    How hard of an install is it?
    12/27/11 - Ordered
    01/16/12 - Received
    Quote Originally Posted by Jabbathewhat
    Not horrible (I've done about a half dozen sets, both with a lift and ramps/jackstands); the pin is the most difficult part. While you're there, you may as well install the rest of the bushings, though.
    TiC sells a complete kit:
    06-08 5MT Holy Shift Kit (Wide)
    Doing the transmission mount / crossmember bushings wouldn't be a bad idea either, since you'll be right there.
    Aug 2011
    Dobbs Ferry, NY
    I have an '11 and I have that same wiggle when in first gear and yes I'm running stock everything on my car at the moment.
    I've only tried wiggling in first though.. so I'm not sure about the other gears..
    Dec 2011
    Pembroke Pines, FL
    Quote Originally Posted by Alternet View Post
    Glad to hear that. If you get a chance to see if it does it in other gears, I would appreciate it.
    12/27/11 - Ordered
    01/16/12 - Received
    Dec 2011
    Pembroke Pines, FL
    Good to know. I will do the whole shabang when I go at it.
    12/27/11 - Ordered
    01/16/12 - Received
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    Keep in mind even with bushing your shifter will still have a slight bit of movement but you want that. If you notice, when you hit a bump or are on a rough road the shifter shakes or moves some. This is energy that would otherwise be causing unnecessary wear to the transmission. That is why you shouldn't drive with your hand on the shifter.
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
