Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on Noob need help please! Parts recommendations- within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Cactus_Magnet Thanks, Im already on the alignment. Thats in the works for tomorrow. heres the link to ...
    Oct 2005
    Late Devonian
    Quote Originally Posted by Cactus_Magnet View Post
    Thanks, Im already on the alignment. Thats in the works for tomorrow. heres the link to the TiC bushings
    TiC Klunk Killer - RACE
    It did make a difference, but not huge.
    Ah, I see now. You should try the subframe lockdown kit if all of that is installed (it does include the diff mount already). It keeps the whole subframe from shifting around, and since the diff mount is attached to that....
    You'll get some really weird noises when engine braking down hills with that stiff of a mount bushing - just ignore them.
    If they can't get you below -1 front camber, they need to loosen the other strut lower mount bolt.
  2. #17
    Texas, United States
    However, when I read up on it the replacement aftermarket drive shafts require significantly modifying the floor pan with a BFH.
    That's only for the fat 3" aluminum driveshaft. A CF driveshaft, chromoly driveshaft, or even a steel driveshaft will be strong enough in a small enough diameter to not require any modification to make it fit.
  3. #18
    Jan 2011
    Phoenix AZ
    Hey, where do i find the Subframe Lockdown>??
  4. #19
    Oct 2005
    Late Devonian
    TIC
  5. #20
    Jan 2011
    Phoenix AZ
    Ok, Im a little confused. I installed the Outrigger bushings that came with the kit. I saw the other mounting points of the chassis, However, I do not see anywhere in TiC a part for sale that is called the Subframe kit, Only the one for the outrigger, which i already have.. Would another brand carry these that you would reccomend? Im goin on the hunt for em now.
  6. #21
    Oct 2005
    Late Devonian
  7. #22
    Jan 2011
    Phoenix AZ
    AH, Nice! Thanks Myco! That all there is to it> 2 bolts? Hmmm.. didnt see that coming. I thought id be pressing moar bushings out again. Thanks again. I will let you know how it goes when im done.
