Many brake combos, same problems. - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on Many brake combos, same problems. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Tinywagon Dude, really? What's your problem? RF, LR, LF, RR every time. The tap was just something ...
    Administrator
    May 2003
    Quote Originally Posted by Tinywagon View Post
    Dude, really? What's your problem? RF, LR, LF, RR every time. The tap was just something else I tried, and it has gotten air out in the past.
    Thanks for the information, I didn't know that about the dual stage booster. I have some speedbleeders, but I also have a friend that helps me do the bleeding. I'm not looking for a decrease in stopping distance over stock or anything, i'm just looking to get my brakes back to stock condition, will a single stage booster have any effect on this or is it just a "pedal feel" mod?
    I'm trying to help. If you are 100% positive you have absolutely no air or no leaks in the system, replace the master.
    If you know how to bleed brakes, you will be 100% sure. If you don't, try doing it correctly.
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    This might be the problem.. traditionally you start farthest away and work your way closer to the master cyl. RR, LR, RF, LF
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Registered User Tinywagon's Avatar
    Mar 2009
    Fort Worth Texas
    Quote Originally Posted by Trainrex View Post
    Okay, thanks. I'm sure there's no air and I'm sure I have no leaks. So I'll go track down a new mc.
    "if you are going to tell someone the truth you had better make them laugh otherwise they'll kill you" - George Bernard Shaw.
    Bugeye Mafia #214
    Dirty Crew #42
  6. #19
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by mangostick View Post
    Thats not how you bleed brakes on USDM WRX/STI with ABS according to the FSM.
    2002 FORESTER S
    1998 FORESTER S
  7. #20
    Oct 2009
    ^ good info, this is why I mentioned "traditionally" ..
    I had a feeling with all the extra abs parts and plumbing that the order might be different. Either way I'd say the op should have the car power bled or at very least run through the bleeding procedure a few times with a couple hours of settle in between.
    SWP 2013 FRS
    SUCH IS MANGO!
  8. #21
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    If you have all the air out, its the master cylinder.
    I like my motive power bleeder, but also have a mighty vac for 1 person operation.
    The motive power bleeder is simple fast and very effective.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  9. #22
    Jun 2010
    Hi i dont know if this will help i have a 2002 wrx wagon not quite the same problem but if i brake hard and catch a bump i loose my brakes so i spoke to a specialist in bristol and they recomend you check the bearings as if there's any play it can confuse the abs.
  10. #23
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    I have had this issue before come up in some honda accords I have worked on. Are you positive that you dont have an internal leak in the ABS system or is the abs system completely seperate from the braking system in a subaru? A lot of times the modulator in the abs system starts to consume brake fluid causing air pockets in the system and it feels good sometimes after bleeding then it quickly turns to poop.
    Lead Wrench @ WTF Tuning, LLC
