Results 1 to 4 of 4
This is a discussion on front mount installed now leaks within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ok so i have an 02 wrx i just installed a tda motorsports front mount kit. now when i drive ...
    Feb 2012
    Question front mount installed now leaks
    ok so i have an 02 wrx i just installed a tda motorsports front mount kit. now when i drive it and it starts to boost it leaks. it sounds like a whining noise. but this isnt really the big problem, sometimes like if its not under high boost it doesnt even blow off. any help would b greatly appreciated
    Sorry but what are you asking? You'll have to locate the leak and fix it.
    Feb 2012
    im asking why would it not blow off and if there is a good place to start looking for the leak
    Oct 2005
    Late Devonian
    Because there is no pressure to blow off.
    It doesn't matter in terms of that - your turbo is spinning much more than it needs to or can sustain.
    You can buy a boost leak tester on ebay, and I recommend it, but you need to read up and be careful (loosen the oil filler cap). You can make things much worse with one if you blow a seal.
