well having now over $100,000(no not just ratchets) in tools in the shop those tool truck bastards still find ways to get my cash...
This is a discussion on Tool Set Recommendation within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; That was me going on about the 6pt. Gear wrenches are not 6pt, and you can't hammer on them anyways. ...
Gear wrenches are not 6pt, and you can't hammer on them anyways. They are nice for after a bolt is broken free though.
These are the kind you can beat the crap out of with a BFH.
Amazon.com: Craftsman 9 pc. Metric 6 pt. Combination Wrench Set, # 47235: Home Improvement
Lead Wrench @ WTF Tuning, LLC
Thanks for the reply. The thing is, I'm looking for a set that includes 17mm (both socket and ratchet), so I can start off with doing an oil change on my car. Combination wrench I guess would be preferred/have more use. If it makes sense for me to buy that one wrench separate, then I suppose I don't mind.
Basically I'm trying to get a set that covers the aforementioned sizes, while at the same time getting what I need to do the oil change.
I was just showing you the pic.
They make various sets, just search for a deal if you want.
Sears: Online department store featuring appliances, tools, fitness equipment and more
I'd get the 18 pc. though.
This? Sears: Online department store featuring appliances, tools, fitness equipment and more
Another newb question also. I noticed it doesn't mention 6 pt., but I'll assume since the wrench is bigger more points are added; thus it will accommodate for 6 pts. anyway?
In that case I'll get that and this: Sears: Online department store featuring appliances, tools, fitness equipment and more
get craftsman 3/8 flex ratchet, real good quality and very handy tool only $30. also the craftsman screw driver pack is cheap i got it for about 15, has three flat heads and one phillips, very heavy duty and good quality also, you can use them to move brake pistons back all day no problem. IMO you can never have enough tools. also i wouldnt recommend buying a set. if i were starting out id get impact sockets, 1/2 and 3/8 from 8-21 at least, also extensions of varying lenght.
LOL full time mechanic?
Ah, no. I didn't see the 18 piece was 12 point. Don't get that.
The nuts are all 6 pts. - it doesn't matter what the size is. The wrenches are either 12 point or 6 point. the 12 point will fit in more positions (angles) but will not hold as well. If you have to hammer on them, they will strip the bolt by rounding over the corners. The 6 pt. will cover the whole flat of the nut so it will not strip. Same for sockets. It is nice to also have the gear wrenches because they will go on the nut in any direction you need (like a regular 12 pt. but better).
Those are good sockets. Eventually you need the deep ones and the shallow ones (deep for bolts that stick out past the nut, shallow for tight spaces).
I don't think the car has any 12 pt nuts actually (I'm not sure because I think one of my cars does but I don't think it's the Subaru).
Thank you. The information has been tremendously helpful.
Finally, I'm looking to get a torque wrench and long breaker bar also. I've come across these- Amazon.com: Gorilla Automotive TW605 Torque Wrench: Automotive
I've also seen 'micro-tork' type torque wrenches; which I presume would be for smaller nuts and such as opposed to wheel lug-nuts? Thanks again for the knowledge.
That torque wrench sounds fine unless you are rebuilding a motor maybe. I could not find the torque range though. I've gotten by without a small one. It it is 110-120 max. there are some suspension bolts it might not do all the way to max torque, but if you've gotten that far you need an alignment anyways and they can torque it the last bit for you lol.
I'm pretty sure I could break that bar, but if it has a lifetime warranty who cares.
I'm a little late to this party, but I've had a Husky socket/ratchet set for a few years that has been great. It was about $70 at the time, and well worth it. I've been able to do basic mods thus far with it (short shifter, bushings, taillights) and oil changes (1st today!). A good set of grippy screwdrivers, vice grips and an 18V power drill are also good to have. Next on my list is a torque wrench.
I definitely believe in buying a quality tool once rather than buying some cheapo tool three times over.
I have a low Reynolds number
TP Stage 1 - 2012 WRX Premium 5-Door SWP
Pics!
