Not getting any power from my turbo. - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
This is a discussion on Not getting any power from my turbo. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Yes the exhaust is relevant - it is what spins the turbo. Do you have your original uppipe still in ...
    Oct 2005
    Late Devonian
    Yes the exhaust is relevant - it is what spins the turbo. Do you have your original uppipe still in there?
    It could also be the turbo. In fact if your turbo ate your uppipe cat it could be both.
    Jul 2011
    Utah
    Yes it is still the original up pipe! My we pulled my buddies turbo out on his wrx there was a screen in his up pipe.. However when I pulled mine off there was no screen?? Could my turbo have eaten the screen?? I have a new up pipe and a new set of headers that havent been put on and are brand new.. Should I put those on and get my turbo rebuilt? (I havent already put them on because in order for them to fit I will need a STI oil pan Becasue they are equal length)
    Oct 2005
    Late Devonian
    Install the UP then see if it works, or do it in one shot. THe turbo might not have a problem, but you wil have the DP and the UP off of it already so it is half way out.
    If the blades or anything got trashed it is a paperweight. Even a good one is margin to rebuild vs. replacing with a used takeoff value and effort wise.
    Oh and post some pics when you have it off or figured out.
  6. #19
    Oct 2005
    Late Devonian
    Should look like this, otherwise the turbo is done too (nothing can go through it without breaking something):
  7. #20
    Jul 2011
    Utah
    I have not had the garage space to take it apart and take pictures but i know for a fact that the screen in the uppipe isnt there! So your saying that if this screen is missing the turbo is probably shot?
  8. #21
    Oct 2005
    Late Devonian
    Unless someone gutted your uppipe.
  9. #22
    Jul 2011
    Utah
    Well I guess its just trial and error?.. I get my tax returns in a couple of days so i'll be able to find out exactly whats going on and then buy what I have too to get her on the road!!
  10. #23
    Oct 2005
    Late Devonian
    Yeah, it is your decision - we can only really guess at stuff without being there. If a Subaru tech looked at it I'm sure there is a good reason they are saying exhaust though. The type of turbo damage these do is obvious (broken fins etc).
  11. #24
    Jul 2011
    Utah
    Well that will be the first thing I check out and hopefully that is it!
    Also another problem has come up! I went to pull my car in the garage last night and it was sputtering like crazy! I had a about a foot wide trail of gasoline following me from where I pulled away all the way to when I parked it.. I looked at it and couldnt see anything.. So I started it back up and then ran to the front of my car to see fuel shooting out of my rear driver side injector! hahaha can an injector go out? is it just not down tight enough maybe? I swear its just one problem after another!
  12. #25
    Jul 2011
    Utah
    Well The fuel problem is fixed!! Replaced all rubbers on the injectors and I'm not leaking anymore! PHEW!!!
    In the process I have gained some of my boost back! I will push about 5lbs but that is still better than none! I dont know if it makes a difference but I'm running 100 octane from the pump right now! I disconnected the battery so that my ECU could make the adjustments as well!
  13. #26
    Oct 2005
    Late Devonian
    Good job on fixing the fuel leak - congrats! I wouldn't try to boost it until you take care of the other issue.
  14. #27
    Jul 2011
    Utah
    Thank you I'm not boosting much and I had a guy at shop7 look at it yesterday and he told me that it is probably my BOV so he welded it to my FMIC piping and i'm going to pick it up today and see if that fixes the problem!
  15. #28
    Mar 2017
    San Antonio TX
    Did you ever fix the turbo problem? My 02 wrx gets in and out of power past 4K RPMs. At WOT my revs will go up then down about then back into power. Then back down a bit. Is that what yours did?
  16. #29
    Registered User Goose42's Avatar
    Jun 2014
    PNW
    pssssst, this thread is five years old. Deano has not been on since June of 2012.
    Or he is rolling down the street in his new slammed ride vaping out the window, enjoying the tow truck ride. - XJman
    2017 ISM Impreza 5MT Hatchback Sport
    2015 WRX COBB Surgeline Stage 2 Pro Tune (Sold)
    Journal-
    http://www.clubwrx.net/forums/builds...ml#post3579257
  17. #30
    Oct 2005
    Late Devonian
    Quote Originally Posted by Jerek.WRX View Post
    Your clutch is slipping if your RPM do not match your speed at all times.
