Results 1 to 12 of 12
This is a discussion on Car started whining today then this!!!! HELP! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have no clue how this happened but just the other day I heard a whining, and then today when ...
    Jul 2009
    Jacksonville, Florida, United States
    I have no clue how this happened but just the other day I heard a whining, and then today when I got home i checked under my hood and found this awesomeness. Anyone have any type of clue what it could be … the belt itself is loose, and then there's this strange circular thing that looks half shredded… please help
ID:	101930Click image for larger version.
    It looks like the tensioner seized and failed. Get two new authentic Subaru belts and another circular thing (pulley) and replace them. Since the bolt looks worn someone's been in there at some point.
    Jul 2009
    My car is a 2003 Subaru WRX, Stage 2, 116k miles on it. It runs like a dream. If it helps the A/C also just RECENTLY stopped working, I was doing some looking and this might have something to do with that as well. Thank you for your time!
    Jul 2009
    I'm going to have this towed to the dealership tomorrow and fixed I hope. Unless there is a way to do this one your own then I'll be more then happy to do it. What would you suggest?
    Registered User sdlocsrf's Avatar
    Jun 2007
    La Jolla, CA
    It looks like the alternator belt is fine? No reason to get this towed if only the AC belt is busted. Just get the AC belt out from under there before driving so it doesn't get caught up in the alternator belt.
    These parts are so easy to replace with even the simplest set of tools. There is no need to pay someone to do this. Plenty of information on how to replace these already on the site.
    Jul 2009
    Quote Originally Posted by sdlocsrf View Post
    So just cut the Alternator belt off? just order new belts, and tensioners and pulleys?
    Jun 2007
    La Jolla, CA
    Nooo, don't cut the alternator belt (the one that is intact). You will be DOA long before you get to the auto parts store for replacement parts. It looks like only your AC belt is broken, or off the track, just remove that one until you can get around to replacing the belts. You will be without AC until you fix this. While you are in there anyways, replace both belts, they are cheap.
    There is tons of information on this issue and how to take care of it yourself on this site if you take some time to search around. One example or here I came up with this in just one quick search, plenty more info and video tutorials on youtube for how to do this.
    Cheeky Bastage! spirited09wrx's Avatar
    Oct 2009
    Dirty Jerz
    I love instructional videos on youtube...sometimes i forget that they are all user uploaded and that its not a complete database of every repair or modification and get upset when i cant find something (which is rare)
    Zach
    Teh Intern @ WTF Tuning, LLC
    2009 WRB Subaru Wrx Sedan
    Stink eye Mob #287
    N.E.R.D. #43252003274489856000 (the total number of configurations of the Rubik cube)
    "It's not turbo-lag, it's foreplay"
    Jul 2009
    So I found this just hanging by the bottom of what the AC belt. No clue what it is.
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    Quote Originally Posted by jjbrady View Post
    The dealer is the most expensive option for getting this simple problem fixed. If you can't tackle the job yourself, any local mechanic can perform it for 1/3 of the dealer rape you would experience.
    That's the other half of the idler pulley.
    Dec 2011
    Mine did the same exact thing a couple weeks ago, I just cut the ruined belt off and bought a new pulley online. You can drive it with the AC belt off, but the defrost is not as good. I'm still driving it like this because I'm more worried about dealing with the other problems it's having.
    Jun 2007
    La Jolla, CA
    You can also get the parts directly from your dealer if they have a parts shop (which I think most do?). I have found that half the time the parts guy will walk me through the install verbally if I am confused about anything when I go to pick up my parts.
