Results 1 to 5 of 5
This is a discussion on P0335 car won't start within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Im getting the crank position sensor code on my 02 wrx The car will not start or crank over I ...
    Feb 2011
    NYC
    I bought a replacement sensor, where does it go? If someone could post a diagram or detailed instructions that would be great.
    Thanks
    Look on top of the motor toward the front near the A/C and alternator, on the top of the block.
    Feb 2011
    NYC
    Would I need to remove the alternator to get to the sensor?
    Feb 2011
    NYC
    I replaced the sensor and my car still won't start. Could it be the starter?
    The car won't even crank when I turn the key.
    Jun 2009
    Quote Originally Posted by cummlns View Post
    Did you ever figure out what was wrong?
