2012 TPMS (issue) keeps turning off and on - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
This is a discussion on 2012 TPMS (issue) keeps turning off and on within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by T0rque check the spare tire.. Does anyone know if the spare tire has a sensor? they usually ...
    KHP
    KHP is offline
    Registered User KHP's Avatar
    Oct 2010
    Reno, NV
    Quote Originally Posted by T0rque View Post
    check the spare tire.. Does anyone know if the spare tire has a sensor? they usually do have tpms sensors also and could be tripping a light.
    My spare tire doesn't. So I would think non of the 2011 WRX's have them.
    2011 WRX Limited Spark Silver (5 Door)
    mrd
    mrd is offline
    Registered User mrd's Avatar
    Nov 2010
    Livermore,CA
    I think that I've read somewhere that only 4 tpms could be registered to one car. That's the reason I didn't put tpms to my winters. Would have to go to dealer every time I change my tires, or buy the device to do so.
    Registered User fbjr2003's Avatar
    Jul 2012
    Chesapeake, VA
    Quote Originally Posted by rage-wrx View Post
    I'd check the cold tire pressure first.You cannot tell if pressure is upto spec by looking at it.A drop of 5psi will trigger the TPMS.
    Spec can be found on the driver side door jamb.
    Love the front bumper lip
  6. #19
    Apr 2013
    I just bought a new wrx last sat and my tpms light comes on after ten minutes of driving. Think they over inflated too
  7. #20
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by jonkim View Post
    Check your tire pressure. If the tire pressure is fine then bring it back to the dealership to have them recalibrate it.
  8. #21
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Overinflated doesn't turn the TPMS light on, nothing happens in that case. Other than bad tire wear, that is. But I had several occasions where just cold outside temps would to it.
  9. #22
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    IIRC someone posted how his tires were severely over inflated & this triggered the TPMS. He let the air out & the light went out.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
  10. #23
    Registered User W_R_XTC's Avatar
    May 2012
    brunswick ohio
    Quote Originally Posted by Ingo View Post
    false. severely overinflated tires will cause the TPMS light to blink and stay on indicating a fault in the system. also a rapid drop or increase in approx. 2psi will also trigger the light for a short time until the system sees a stable pressure. i.e. large pot hole
  11. #24
    Aug 2010
    Yonkers/NYC
    I correct myself. Actually read that in this thread some time ago,LOL.
    T0ny
    2011 WRX
    2012 FXT
  12. #25
    Aug 2012
    Alexandria, VA
    Most Japanese imports are shipped with high tire pressures to protect them from getting "flat spots" or other tire related problems that could occurred from sitting for long periods of time. I have taken delivery of numerous imports and the dealership failed to adjust the tires to the proper vehicle rating. I check my tire pressures now on all my new cars. It's kinda sad during pre-delivery inspection this gets missed a lot.
  13. #26
    Aug 2012
    Tucson, AZ
    depending on how bad the tires are over inflated, the light may or ma not come on.
    also, typically, spare tires will not have a sensor unless its a full sized spare. I still have yet to see a sensor on a temporary spare tire.
    I have also seen m tpms act up on my car. I had a nail in one of my tires, plugged I, reset all the pressures, and a week later the light came back on. checked all the pressures and they were all still at factory specs. put the car on the lift and ran it in gear roughly a mile and went off
  14. #27
    Mar 2012
    OK, I stand corrected, maybe. Don't really care, I have not yet had any serious over-inflation. It would be good habit to check sometimes anyways, just like oil level and such. People are just getting WAY to lazy with the modern gizmos. These things are still cars that need a certain amount of care and also a way of handling that I find many people today are simply missing. Like not turning the steering while the vehicle is stationary, or not pulling the steering wheel against the stop, ever. A good tire pressure gauge is a must...
