Is "high mileage" oil bad?
Results 1 to 5 of 5
This is a discussion on Is "high mileage" oil bad? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; It's all I can find in 10W40 synthetic....
    Registered User mmiller2002's Avatar
    Nov 2007
    Ft. Worth, TX
    '02 WRX Wagon
    RCE wagon springs
    Koni inserts
    Com-C Top Mounts
    Kartboy Endlinks
    Sedan rear swaybar
    Others little stuff
    Quote Originally Posted by mmiller2002 View Post
    No, it's fine.
    You could also look for a 5W-40 synthetic and use that year-round in your area. Shell and Mobil both make this. The Shell is usually very well priced.
    Les jeux sont faits.
    Nov 2007
    Ft. Worth, TX
    Where?
    '02 WRX Wagon
    RCE wagon springs
    Koni inserts
    Com-C Top Mounts
    Kartboy Endlinks
    Sedan rear swaybar
    Others little stuff
  5. #4
    mrd
    mrd is offline
    Registered User mrd's Avatar
    Nov 2010
    Livermore,CA
    Higher number of oil viscosity higher temperature is needed to get the engine lubricated. In coastal tx I'd say you'r okay with 10-40, but in lower temp areas 5-up would be a better choice.
  6. #5
    Where?
    If you can grin and bear it, Walmart. Look for 4QT jugs of Shell Rotella T6. Buy an additional quart to make the 5 you'll need, or better yet just buy two 4QT jugs and keep the left over oil for topping up and for the next oil change. They also stock M1 5W-40 (look for "diesel truck" M1 in that viscosity) but it is more expensive and not worth the extra $ over the Shell in my view.
