Can I get an idiots guide to changing oil in a 2011 wrx sedan? Help me save $!! - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
This is a discussion on Can I get an idiots guide to changing oil in a 2011 wrx sedan? Help me save $!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; if you take your oil cap off before popping the drain, it'll drain a lot faster....
  1. #31
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  3. #32
    Moderator Donkey's Avatar
    Da boonies,Va
    Takes about 5 minutes to drain with the Fumoto valve.
    2002 FORESTER S
    1998 FORESTER S
  4. #33
    Registered User sjcurtis's Avatar
    Sep 2010
    Selma, Alabama
    I use a K&N oil filter and I always fill it up before I start changing the oil and let it sit, then when I am ready to put it on I top it off again. This way the oil filter is already full and the oil can go where it needs to be instead of having to wait til the oil pump fills it.
  6. #34
    Oct 2005
    Late Devonian
    I didn't know about the Fram deal - is that when the stopped selling the black OEM filters?
    I would wonder if a Fram filter that is built to Subaru's specifications would be materially different than one built by another manufacturer for Subaru. Still, it does give me pause.
  7. #35
    I don't know that Fram would be a limitation at this point. Subaru motors don't need an anti-drain valve, and the filtering medium should be adequate. The real issue is pressure, and from what I've seen only Subaru and STP sell filters with the correct bypass pressure anyway. I've used the STP on my Subaru and I've used Fram on my Toyota (but to be fair the Toyota only has 260,000 miles on the motor so it's not even broken in yet...).
    At this point I shop by bypass pressure and if I can't find something within spec, I shop by price.
  8. #36
    Nov 2006
    Denver Metro Area
    explain the bypass pressure if you would spiros
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  9. #37
    Generally,
    Subaru Oil Pump Specs as Relates to Filter Bypass - Bob Is The Oil Guy
    Now those guys take lubrication very seriously, and it it unclear to me what would happen if one were to use a filter with an incorrect bypass pressure. Likely, absolutely nothing, since I think more people use the "wrong" filter than use the correct filter (there are only two sources of correct pressure filters in the US as far as I know...).
    In the used oil analysis section on Bob's site there are lots of Subaru UOAs and the particulates are generally low regardless of filter used; I wonder if this means the bypass pressure issue isn't as much of an issue as some might think.
    It seems from the specs and discussion that the filter is bypassed most likely at high rpm with cold oil, and this shouldn't really be happening all that much anyway.
    Since I generally can get the "correct" filter, I do though.
  10. #38
    Registered User Wussola's Avatar
    Sep 2011
    Portland, ME
    Quote Originally Posted by synolimit View Post
    gonna mod this a bit
    Sorry I know this is an older post, but had a quick question about re-installing a new oil filter.
    I've been changing the oil on my cars and motorcycles for years. I've always tightened it by hand and then gave a 1/4 ish turn with a filter wrench (the one that nicely fits over the end like a socket). However, when I review the manual for my 2011 WRX it recommends that the oil filter be tightened to 12 Nm. I did this the other day with my torque wrench and it seemed like I really had to tighten it on there ... more than I'm used to ... before I reached 12 Nm. To me it felt like it was overtighten ... but it was per factory specs. I just don't want to warp the gasket and end up with an oil leak. I was wondering what peoples thought are on this and what they typically do.
    Thanks in advance!
    2011 Subaru Impreza WRX (Premium) | EFI Logics Tuned Stage 3 | Cobb SF CAI | Invidia EL Race Header | Cobb Catted Downpipe | Borla CBE | PW TMIC | Grimmspeed EBCS | Grimmspeed AOS | DW 65C Fuel Pump | Grimmspeed Light Weight Pulley | SPT Short Shifter | JNA Front Lip | EPIC Performance Springs | SMY Cluster w/ Boost & Oil Pressure
  11. #39
    12 Nm is attainable by hand.
    I never use a wrench on the filter in any of my cars. I tighten all the way by hand. Never a problem.
  12. #40
    Oct 2005
    Late Devonian
    Roger, as long as it isn't slippery you can just tighten it by hand.
  13. #41
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    I ALWAYS tighten by hand. There is nothing worse than the occasional oil filter that has to be entirely dismantled to get off. Had a couple of those, usually the first one on the used car I got last. Never again. I'd rather have to tighten some more due to finding it leaking a bit...
  14. #42
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    -_- I was never worried that I had an inappropriate filter until this thread got bumped. Now I've wasted an hour and developed a mild paranoia.
    David - '05 WRX
