Timing belt replacement
Results 1 to 14 of 14
This is a discussion on Timing belt replacement within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys, I have an 04 WRX with 120k on it; I wanna replace the timing belt but I dont ...
    Nov 2011
    Hey guys, I have an 04 WRX with 120k on it; I wanna replace the timing belt but I dont know if I should replaced idler pulleys and tensioner too, cus they are crazy expensive, what are your thoughts?
    Jan 2005
    Eh, whaaaaa?
    Tensioner, definitely. I'd say definitely on the idler pulleys as well, but that's up to you. Personally, I'd rather be safe than sorry. The timing system is extremely sensitive and extremely important, I wouldn't take any chances with any of it.
    Better to spend the money now than 10 times the amount or more later.
    Cody
    Moderator Donkey's Avatar
    Da boonies,Va
    You can generally buy kits that come with belt,tensioner and pulleys all together. Generally saves some $$$
    2002 FORESTER S
    1998 FORESTER S
    Jan 2005
    Eh, whaaaaa?
    Cody
    Registered User 06ImprezaWRXSTI's Avatar
    Aug 2009
    Lawrence, MA
    +1 Spend the extra cash now. Like the other guys said better to be safe than sorry. My bugeye has 119K miles I bought it with bent valves because the timing belt gave up. And all the pulleys and idlers including water pump don't look too good.
    Also replace the rear main seal, cam seals, oil pump seal. Best choice IMO.
    WTB: 02-07 Impreza WRX or STi crashed.
    I used Gates for everything except the pump gasket and thermostat gasket.
    Get the thermostat itself, the pump gasket, the thermostat gasket, six cam seals (you need four), two crank seals (you need one), one crank bolt, two containers of blue Subaru prediluted coolant, one bottle of coolant conditioner, and a partridge in a pear tree from the dealer.
    The bolt for one of the pulleys has changed length. See if you need one of those too. The pulley has changed width so depending on what your car has you may need the newer bolt too. I did not.
    Do the outside belts also. Buy those from the dealer only since the imitation belts make noise.
    Nov 2011
    I took covers of my car to see how it looks, and it has a Contitech(made by Continental) timing belt on it, does this mean it has been replaced?; Does anyone knows what is the brand for the stock timing belt?. Thanks everyone
    Quote Originally Posted by rockero View Post
    If your car is a US model, yes.
    Gates is the supplier in the US.
    Nov 2011
    I did a background check before a bought it, and it did show to have been sold here in US; Has anybody ever heard of this Timing belt brand?, It doesn't seem to be quite as popular as Gates?
    Continental is a well known firm.
    Jan 2012
    UT
    What is the best manual to get to for an 06? Book or an online source? How long does a TB job take?
    Quote Originally Posted by 1brine1 View Post
    Subaru.
    A weekend.
    dab
    dab is offline
    Feb 2012
    Hi there, I have a 2002 bugeye with 17,000 genuine miles on the original cambelt, should I change it because of the age, do the belts degrade with age?
    Quote Originally Posted by dab View Post
    It is past due. The owner's manual for the US car states 105,000 or 105 months (I think; in any case it specifies an age and you are certainly beyond it).
    If you are curious, contact Gates and ask what effects ozone and/or other components of the atmosphere have on the belt over time, and go from there. You could ask directly if they recommend a change due merely to time.
