Results 1 to 13 of 13
This is a discussion on O2 sensor within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey, I threw a code for running lean in chamber one. So I replaced my front o2 sensor, then cleared ...
    May 2011
    NJ
    O2 sensor
    Hey, I threw a code for running lean in chamber one. So I replaced my front o2 sensor, then cleared the code. It stayed off for about 200 miles then came back on. So, my question is, should I look for another solution or is it normal for the CEL to come back on for a while?
    There are no modifications to the car, bone stock.
    "when the turbo spools, it's like you're in a time machine"
    What was the CEL code number?
    May 2011
    NJ
    P0171 System Too Lean (Bank 1)
    Clean the MAF. Clean intake, replace air filter, seal filter housing correctly. Confirm vacuum connection to fuel pressure regulator. Confirm no vacuum or boost leaks. Search PO171 for more detailed troubleshooting info.
    May 2011
    NJ
    Thank you.
    Registered User JLong's Avatar
    Sep 2011
    Pittsburgh, PA
    Ughh you guys on here are so knowledgeable! That looks like freaking Chinese to me.
    Lando Calrissian DemonWRX's Avatar
    Jul 2011
    Cloud City, Bespin
    Odd...cause the car was made in Japan
    Stink-Eye Mob #39
    N.E.R.D. Operative #8
    Sep 2011
    Pittsburgh, PA
    Quote Originally Posted by DemonWRX View Post
    lol touche
    Aug 2012
    I'm throwing this same code and I found some oil in my intercooler? Any ideas?
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    How much oil? Some is normal.
    Lead Wrench @ WTF Tuning, LLC
    Yes residue is not abnormal and I can't picture right now how it might relate to PI171. I'd troubleshoot as above and reset the ECU, and see what happens.
    Aug 2012
    Just a little. But I've done the maf sensor and almost everything else. I'm running out of ideas. O2 has been changed. New filter. Changed the boost hoses. Checked all my vacuum lines changed what was needed.
    Aug 2012
