09 2.5i impreza normal oil consumption
Results 1 to 2 of 2
This is a discussion on 09 2.5i impreza normal oil consumption within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; What is considered normal oil consumption for a n/a 2.5 manual impreza. Going through about quart to quart and a ...
    Registered User WrRexgoliath's Avatar
    Aug 2009
    Denver, CO
    What is considered normal oil consumption for a n/a 2.5 manual impreza. Going through about quart to quart and a half every 4k
    Normal consumption is stated in your owner's manual. Typically makers don't want to listen unless you're going through more than 1L per 1500 km or so.
    If there are leaks, fix them. Also consider trying a different oil brand, but always stay with API oils of the correct grade and viscosity.
