Stiff and whining steering wheel! Help!!!
Results 1 to 5 of 5
This is a discussion on Stiff and whining steering wheel! Help!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok so yesterday saw my wrx 2004 needed some power steering fluid, so I put some to where it say ...
    Nov 2011
    Downey
    Exclamation Stiff and whining steering wheel! Help!!!
    Ok so yesterday saw my wrx 2004 needed some power steering fluid, so I put some to where it say "max". And then I
    Turned on my car and tried to turn the wheel it started to whine and got really stiff. Do I need a new power steering pump? It also started to leak there the pump is. What should I do?
    Jul 2010
    Cincinnati
    Sounds like you have a leak. I think if you fix the leak and bleed the system of air, your issue should be solved.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Nov 2011
    Downey
    Quote Originally Posted by jd92677 View Post
    How do I do that?
    Find the leak and fix it. Refill with the correct fluid from Subaru. Support the front using jack stands and with the power steering reservoir cap off and the motor on, turn the wheel end to end several times.
    Nov 2011
    Downey
    Well on the pump is where it leaks the fluid. I see fluid in the container bubbling up. It looks like if it's boiling with all the bubbles.
