Boost gauge help
Results 1 to 2 of 2
This is a discussion on Boost gauge help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So a couple weeks ago i blew a vacuum line and at the same time that happened my boost gauge ...
    Oct 2011
    Wilkes, NC
    Boost gauge help
    So a couple weeks ago i blew a vacuum line and at the same time that happened my boost gauge starting registering "0" constantly. I assumed when i fixed the vacuum line that it would return to normal but it's still stuck on "0'. So i checked around the t splitter(not sure on technical name) and couldnt find any leaks so what else should check? does the gauge need to somehow be reset? its a cobalt boost gauge and its in a three gauge pod on the center of my dash
    Blobeye Syndicate #1313
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    sounds like the boost gauge is just no longer connected to the vacuum lines. Check all the lines going to the gauge and see what's up.
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
