Results 1 to 3 of 3
This is a discussion on One fog out, bad relay? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Okay so one foglight is out on my 06 WRX, its not the bulb ive swapped them it must be ...
    Sep 2011
    Okay so one foglight is out on my 06 WRX, its not the bulb ive swapped them it must be wiring or the socket or something. I took the foglight relay out from behind the steering trim, it has 4 prongs two of which are silver. The other pair of prongs, one is gold, and one has a reddish rainbowish color to it, does that mean the relay is bad?
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    It's almost always mud/corrosion in the plug behind the fog. I took mine apart, and cleaned the plug out with a brush, plugged it in, and it worked.
    Sep 2011
    okay thanks ill try that first
