Engine oil plays hide and seek.
Results 1 to 6 of 6
This is a discussion on Engine oil plays hide and seek. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello fellow wrx owners , I'm having a problem with my wrx . My car tends to burn oil from ...
    Jan 2008
    mn
    I'm having a problem with my wrx . My car tends to burn oil from time to time ,Yesturday I'd checked the engine oil and it was empty, so I want out
    and bought 2 quart of oil to refill it , took the car out to work on the following day , when I got home I check the oil level , and it double.
    So where all the engine oil goes and where it all coming back from?.
    Registered User v6mx6ls36's Avatar
    Jan 2009
    El Paso Texas
    When are u checking the oil . U should drive it and then park and wait about 15 min to let the oil sink back down into the pan . If your checking it right after u shutdown that may be why your not seeing much oil . An then if u check like in the morning before work your gonna see alot more since it drained down over night . Check it after its been driven and wait 15 min.
    Jan 2008
    mn
    Quote Originally Posted by v6mx6ls36 View Post
    I did let it sit for more than 15 mn. Not sure what where those oil went if not burn.
    Oct 2011
    Also make sure you are on level ground or it won't be the correct reading.
    Sent from my SGH-T959 using Tapatalk
    Apr 2007
    8000' up in Colorado
    What they said. You need to let it sit for a while before checking, and do it on perfectly level ground.
    Scott
    Jan 2008
    mn
    Quote Originally Posted by greyscooby View Post
    I'm aware of all that ,my drive way is fairly level and is been parked for about 30mn before I checked the oil level.
