timing belt guides early 2002 WRX
Results 1 to 7 of 7
This is a discussion on timing belt guides early 2002 WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have not personally seen the the insde of the cam covers and was wondering if the early 2002 WRX ...
    Dec 2011
    Nevada
    I have not personally seen the the insde of the cam covers and was wondering if the early 2002 WRX had those Timing belt guides at the cam gears like the newer WRX's?
    If this was a update, is it available without changing the heads?
    when was this updated?
    Jul 2011
    CT/OH
    Mine had them on the upper and lower left side timing cover, and lower right hand side. Not sure the year of my motor though, but the chassis is an 02, and I'm sure much updating wasn't done on the 2.0's in the 4 years there were used, pertaining to the timing belt that is.
    Dec 2011
    Nevada
    thanks?
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by theblurz View Post
    All USDM WRX's and STI's have the marks on the cam gears. In fact it would be fair to say pretty much all Subarus (OBDI and OBDII) have the marks.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2011
    CT/OH
    Sorry, I completely read that wrong.
    For the 2.0, the top cam and bottom sprockets have two marks, one is a single line, the other is a double. The top cam gears single mark aligns to the 12 o'clock position, there is a line in the timing belt cover, the bottom gears mark aligns at the 3 o'clock position for the drivers side cam, and the 9 o'clock for the passenger side.The best way I found to align the bottom marks is to use a thick feeler guage and stick it in the groove on the timing cover, and turn the cam sprocket until it lines up. The double marks align with each other on the cam gears. I hope this helps you, as my other post was clearly way off topic.
    Dec 2011
    Nevada
    I'm confused. How did we get to "Marks" I was speaking of the timing belt guide plates.
    Da boonies,Va
    Ah....then I misread. There are 4 total as I recall.
    2002 FORESTER S
    1998 FORESTER S
