Help with off throttle engine noise 2011 wrx
Results 1 to 8 of 8
This is a discussion on Help with off throttle engine noise 2011 wrx within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 2700 miles, faint high pitch ringing in all gears when decelerating or maintaining 4100-4800 rpm. Happens also in neutral. Noise ...
    Registered User Anzioblack44's Avatar
    Sep 2004
    CHICAGOLAND
    2700 miles, faint high pitch ringing in all gears when decelerating or maintaining 4100-4800 rpm. Happens also in neutral. Noise is not present when accelerating through that powerband. Sounds kind of like a pulley or belt... Any ideas, first dealer service coming up. Not sure what I should make sure they check. Pisses me off cause I want to go to an ots tune this spring, but I'm holding off till I know the car is ok. Thanks for any input
    2011 SWP 5 door WRX LIMITED
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Take it into the dealer.
    Lead Wrench @ WTF Tuning, LLC
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Quote Originally Posted by T0rque View Post
    +1. Considering the recent drop in temps, I suspect a belt. Does it go away after driving for a while? Did you try spraying? If not, I bet they will.
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
    Sep 2004
    CHICAGOLAND
    Appointment booked. Noise doesn't fade after extended driving. I'm hesitant to spray the belt because its not squeaking or squealing. based on sound I'm thinking Maybe a faulty tensioner or pulley. I'm hoping nothing serious is wrong
    Jan 2011
    Crofton, MD
    When its doing it, does the ringing sound "fluttery" or constant?
    Greg
    Build Thread
    Sep 2004
    CHICAGOLAND
    pretty much constant, i can hear it very faintly outside the range of 4100-4500, but its audible much more apparently in that rpm range. I do notice that if i transition to light throttle the noise seems to dissapear. I wonder if something is resonating, i know our clutches/flywheels are very noisy for a stock car. my cobalts exedy 6 puck wasnt much louder.
    I get that classic my09 deceleration noise when in 2nd below 2000rpm. I can put up with these noises if they are normal, im realistic its not a BMW, and im willing to compromise. I just want to know that everything is working properly as i plan to have it much longer than i had my cobalt.
    Sep 2004
    CHICAGOLAND
    Took car in, tech was able to reproduce the noise, but claimed that its harmless and somewhat normal, backlash in the transmission, not worth a teardown
    Jan 2011
    Crofton, MD
    Cool, good to know. At least you have the peace of mind knowing that they've looked at it.
    Greg
    Build Thread
