P0032 and P1131 Codes
Results 1 to 10 of 10
This is a discussion on P0032 and P1131 Codes within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Sooo I get two codes P0031 HO2S heater control circuit high Bank 1 Sensor 1 and P1131 Oxygen Sensor Malfunction(Short ...
    Dec 2011
    Chesapeake, VA
    Sooo I get two codes P0031 HO2S heater control circuit high Bank 1 Sensor 1 and P1131 Oxygen Sensor Malfunction(Short Circuit). I purchased a new DENSO front oxygen sensor and threw it in. I recet the ECU and the CEL comes right back on within 5 seconds of the car being on. I erased it and reset the ECU again with no luck. I have been trying to put this car together and every time one thing is fixed, another one comes up. I just replaces the Throttle Position sensor due to a CEL and I get O2 codes now. Please help!
    Dec 2011
    Chesapeake, VA
    Took the car around the block, first time I drive it since I bought it. It was sluggish, barely creeping, new code P1093 TGV 2 system closed together with P0031 and P1131. Amazingly the codes multiply as I throw parts at it.
    Apr 2007
    8000' up in Colorado
    It would be a good idea to start with year/mileage/mods/maint history/ownership history/code history.
    Scott
    Dec 2011
    Chesapeake, VA
    2002 wrx,106k, manual,3" turbo back, perrin intake and TMIC. I purchased the car without a starter, major oil leak and fuel leak on driver side. Fixed the leaking fuel rail and the oil leak(turbo line). Put in a starter and it started right away, threw a code for the TGV sensor. I replaced it and spring loaded it like it was supoused to. Started the car and it showed P0031 and P1131, replaced the front O2 sensor and reset the ECU, still the codes remain. Went for a 2 min. drive and now I have P1093, P0031 and P1131. i remember I had to take off the TGV motor to get to a bolt and put it back on. That was before being aware of the spring loading. I tried searching for instructions on installing the motor but wasn't able to find out anything. That might explain the P1093 code, but I don't know what to do with the front O2 sensor codes.
    Dec 2011
    Chesapeake, VA
    Update, still baffled on what is going on. I exposed about a foot of the wires to check for anything unusual but everything seems fine. I found a huge exhaust leak betwwen the up-pipe and the pipe that has the cat on it(right nect th the rear O2 sensor). No gasket, bolts are just hand tight. Can that cause the front sensor to be acting up?
    Dec 2011
    Chesapeake, VA
    Purchased O2 sensor from Subaru for $251 and I still get the codes, exhaust leak is between the down pipe and the mid pipe. Is it possible another sensor to be causing the front O2 to act up? How do I run diagnistc mode? Hook up the green connectors and read the codes with my scanner?
    Dec 2011
    Chesapeake, VA
    Update, fixed the exhaust leaks and pre-turbo intake leak I found, still get the codes. Any ideas?
    Moderator Donkey's Avatar
    Da boonies,Va
    I would suspect a harness issue. I suggest purchasing the service manual to help with the trouble shooting. It has the diagnostic "tree" for all the codes in it.
    2002 FORESTER S
    1998 FORESTER S
    Dec 2011
    Chesapeake, VA
    I found a thread somewhere about a guy with a similar problem. No word if he got it figured out, but one of the suggestions was to check timing. I just did and not happy, well kind of. The exhaust cam on the passenger side seems like it is off by a tooth. Middle marks(double) are not perfectly alligned like on the other side. I got some wrenching to do and will see what happens. Please let it be it!
    Dec 2011
    Chesapeake, VA
    I finally figured it out, it was the ECM. I replaced it with used one from e-bay and she is running again.
