Results 1 to 15 of 18
This is a discussion on Jacking up 2005 WRX to change oil. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I currently have a jack and 2 jack stands. I was going to buy some ramps for simplicity but my ...
    Nov 2011
    Fort Bragg
    I currently have a jack and 2 jack stands. I was going to buy some ramps for simplicity but my vehicle is lowered somewhat and the front scapes the ramps. The issue at hand is I do not have a service manual for my vehicle and with searching I cant find pictures of the jack points for the 2005 WRX. any help or vid would be cool, thanks.
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    Behind the front tires you will see a metal ridge, the side skirt opens up and the ridge gets a little taller (about 1/2") that is a spot welded part of the unibody and is very strong (ment to lift the car with) under the front bumper you will see black steel tabs hanging down on each side. Those are tow hooks. Use your floor jack to jack the car up there, place stands under lift point I talked about earlier.
    Lead Wrench @ WTF Tuning, LLC
    Nov 2011
    Fort Bragg
    Any pictures of any of this? This will be my first time doing this and I'd rather not screw up.
    Dec 2004
    Your Mommas
    Ill take some pics of my 11, it will be slightly different but youll get the idea I guess...
    Nov 2011
    Fort Bragg
    Quote Originally Posted by T0rque View Post
    awesome
    Dec 2004
    Your Mommas
    Here it is
ID:	100854Click image for larger version.
    Nov 2011
    Fort Bragg
    Here it is
    Awesome. so i put the jack stand between those "notches"
    also what exactly am I lookin at in the second photo?
    Dec 2004
    Your Mommas
    The second pic is a tow hook, jack the front of the car up with that. That tow hook on your car is going to be a black steel plate with a hole in it.. But it looks similar to the pic of mine.
    Nov 2011
    Fort Bragg
    So do i center the jack on that hook? or do I center it on the black steel place to the left of it?
    Registered User sjcurtis's Avatar
    Sep 2010
    Selma, Alabama
    I hate to sound like a ass but if you can't jack your car up I dont think you should be changing your oil.
    Nov 2011
    Fort Bragg
    Quote Originally Posted by sjcurtis View Post
    I had ramps back at home, but I dont have the manual for my 05. Completely aware on changing oil and filters
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    I don't bother with jacks or ramps. I just park it on a level surface and reach under. Might be harder since you're lowered, I suppose.
    Sent from my DROID2 using Tapatalk
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
    Nov 2011
    Fort Bragg
    Quote Originally Posted by Rambo View Post
    Yeah thats not happening with my currently vehicle height.
    Sep 2010
    Selma, Alabama
    Quote Originally Posted by otakutrevan View Post
    All I'm saying is if you need a manual to jack up your car then wouldn't you need a manual to change your oil? All cars jack points look the same, and you didn't know what a tow hook is so I was just wondering how many cars have you been under?
    Nov 2011
    Fort Bragg
    I need to know about tow hooks to unscrew a bolt, remove a filter, and put a new filter on? I know how to change my freaking oil son.
