Car starts then shuts off..
Results 1 to 12 of 12
This is a discussion on Car starts then shuts off.. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ok so heres my problem i switch my coil packs for goth side making the back to the front and ...
    Nov 2011
    LB
    ok so heres my problem i switch my coil packs for goth side making the back to the front and the front to the back. after i did that my car just starts then shuts off... any ideas much help will be apperciated.
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    Does this happen every single time? When did the problem start? What modifications are done to the car? Does it or did it ever have a cobb accessport mated to it?
    And why did you switch the coil packs?
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
    Nov 2011
    LB
    yeah its like for a quick 2seconds then shuts off. it started after i switch the coil packs. not much modifications, just intake thats about it. sorry but i dont know what a cobb accessport is, and i switch it cause i wanted to see if it would take the check engine light out. the issue with the car is, i have misfire cylinder on all 4 cylinder.
    Apr 2007
    8000' up in Colorado
    Well switching the coil packs certainly didn't help the problem. What specific misfire codes are you getting?
    It sounds like you have a problem that switching the coil packs makes worse.
    Scott
    Moderator Donkey's Avatar
    Da boonies,Va
    Maybe you hooked them backup wrong or if you removed the intake you installed it backwards.The black connectors need to go to the back cylinders and the MAF sensor plug should face the front of the car.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2011
    LB
    at first i had misfire cylnder number 2. then after i switch it. all 4 came back up. one of my coilpack is a bit rusted compare to the others. i did whites in the front, and blacks in the back. and juts right now, i tried to starting my car again, it actually started for 2 seconds then it shut off. when i was gasing it. i am having used coilpacks commin in next week or this weekend. hopefully that would make it start..
    Nov 2011
    LB
    so can you guys tell me what the problem might be? even if your not 100%...
    Da boonies,Va
    Did you remove you intake to check remove the coil packs? Make sure you installed it right. Obviously go back and recheck what you did. Not alot involved with taking off a coil pack and putting it back on.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2011
    LB
    yeah i did all that. i install everything back proper, i cleaned the maf sensor. still the same
    Nov 2011
    LB
    alright what i forgot to add was that my car was boggin to the max. i gas it all the way and it was only going 5-10 mph.. why did this happen?
    Palmyra, NJ
    effed up fuel system at some point?
    Nov 2011
    LB
    thats what im hoping... gonna check out the fuel pump and fuel injectors tommorow. everytime i start my car, it just dies out. does not start at all.
